10-23-2018
09:25
15:03
10-23-2018
09:25
15:03
The step counter on my fitbit 3 is not bright enough to see, if it was the same as the clock face there would be no problem, can it be done??
06-07-2020 05:59
06-07-2020 05:59
Best Answer06-07-2020 09:29 - last edited on 06-12-2020 19:55 by LiliyaFitbit
That’s quite possible. So sorry.
Sent from Gmail Mobile
Best Answer06-09-2020 01:00
06-09-2020 01:00
I use a charge 3 and my fitbit's brightness decreased and now it's so low I can barely see what's on screen and the app is useless.
06-09-2020 01:06
06-09-2020 01:06
The brightness is low I can't even see whether the battery is getting charged and the app is not syncing I don't know for what stupid reason
..it shows 25% charged on app... But do t if that is as of today or it is some days old information... Seriously... Long list of improvements for Fitbit
06-09-2020 05:46
06-09-2020 05:46
Best Answer06-09-2020 09:25
06-09-2020 09:25
I've tried everything to make my Charge 3 brighter and it just doesn't work. I love the looks of the Fitbit 3 but if you can't see it, what good is it. I spend most of my summer outside. Sad.
Best Answer06-09-2020 14:40 - last edited on 06-12-2020 19:55 by LiliyaFitbit
Agreed. You can contact Customer Service and see what they will/can do for
you.
Best Answer06-09-2020 14:41 - last edited on 06-12-2020 19:56 by LiliyaFitbit
True. I will go to another brand when this one quits.
Best Answer06-09-2020 14:46 - last edited on 06-12-2020 19:56 by LiliyaFitbit
That is only controlled by the Fitbit itself. Get the time up and scroll
left in order to get to the screens to the right. On the third scroll the
bottom is Settings. Tap on settings to get to Brightness. Your choices are
Normal, Auto and Dim in that order. I had to do this in a dark room. Still
didn’t help me and since mine was only 6 months old, it was replaced. Good
luck.
06-09-2020 14:47 - last edited on 06-12-2020 19:57 by LiliyaFitbit
Best bet is to contact Customer Service.
Best Answer06-09-2020 15:42 - last edited on 06-12-2020 19:57 by LiliyaFitbit
I opened a "chat" and after 30 min. of waiting, there were still 57
chats ahead of me. Phone in is longer. Back in the day, I could
email them and they always took care of it right away. Now that is
not an option.
The only way to increase brightness is from the display which I can't
see to tap on. grrrrrrr.
Best Answer06-09-2020 17:03 - last edited on 06-12-2020 19:57 by LiliyaFitbit
When I clicked on the link to customer support, it gave me the option to
send an email. You might send an email with very specific information.
Include what you’ve already done to try to fix the issue.
Best Answer06-09-2020 17:22
06-09-2020 17:22
That's how it was with me and I thought it was very fair. They want to know you've tried everything to make sure that it's not defective and I did. When they decided there was a problem they sent me a new one and it is worked perfectly ever since. Thanks guys.
WSS
06-09-2020 20:18
06-09-2020 20:18
Best Answer06-12-2020 14:41
06-12-2020 14:41
Can I increase the brightness
Best Answer06-12-2020 17:24
06-12-2020 17:24
06-17-2020 10:00
06-17-2020 10:00
It’s too dark to even see my settings to adjust brightness. So faint I can’t hardly see the time display. Any other suggestions to adjust the display brightness or what the problem may be?
06-30-2020 05:15
06-30-2020 05:15
How do I increase the brightness on my charge 3 ?
Best Answer07-02-2020 18:59
07-02-2020 18:59
There is no option to swipe left.
Best Answer07-03-2020 21:23 - last edited on 09-10-2020 20:40 by LiliyaFitbit
If going into a dark room doesn’t help you see the display, you need to
contact Customer Service. Good luck.
