05-27-2021
11:00
05:47
WilsonFitbit
05-27-2021
11:00
05:47
WilsonFitbit
Can my charge 3 sync with my YMCA app or E Gym profile?
05-28-2021 05:46
05-28-2021 05:46
Hello @Crystallorraine. Welcome to the community forums!
I'd like to let you know that if these are apps that work with Fitbit, you need to search in their apps the way to connect both accounts, only if these are supported. For more details please refer to this article: How do I connect my Fitbit account with another app?
On the other hand, if these are motion programs, you need to have specific links or instructions for your Fitbit app to communicate with other wellness services. Although this depend on the program you have enrolled and if it is supported by Fitbit.
Otherwise, the best way to tell if an app is compatible with Fitbit is to go to the third party site (or app) and poke around their settings to see if you can connect to Fitbit.
See you around.
