11-25-2020
12:17
10:14
AlvaroFitbit
11-25-2020
12:17
10:14
AlvaroFitbit
I can't adjust brightness on C3 because I can't see the screen
11-25-2020 17:13
11-25-2020 17:13
Try in a darker location. You will need to find someplace with a light level less that what the tracker has.
11-26-2020 11:25
11-26-2020 11:25
11-26-2020 11:53
11-26-2020 11:53
Then contact Fitbit.
I'm still trying to figure out what a long boot is. We have a soft(ware) restart and a Hard(ware) restart. A hard restart requires a complete shutdown if the tracker.
Best Answer11-26-2020 14:44
11-26-2020 14:44
I just had the same thing happen to me. My screen has been mostly gray and sometimes striped in different shades of gray with a black line on one side for months despite being restarted and unsynced. Today I was having a look at the settings to see if changing the light level from auto would help, and suddenly all the text disappeared into a dark gray haze.
10:17
07:41
12-01-2020
10:17
07:41
@TaniaD67 @Cerizas I hope you are doing fine.
Let me help you with your Charge 3 screens not working and thank you for confirming with @Rich_Laue that you have restarted the devices. Since the issue persists I have created a ticket so our Support team can further assist you via email.
Let me know how it goes.
12-01-2020 10:36
12-01-2020 10:36
Thanks for offering to help. I'm not sure how it happened, but either the screen lightened up some or the lighting in my room at 10am the next morning was just right.. Either way, I was finally able to see a lighter smudge where the text should be and find the settings screen again. From there, I got my lighting set back to auto.
11:21
07:41
12-02-2020
11:21
07:41
@Cerizas thank you for your reply.
Happy to hear that your Charge 3 is working fine correctly after troubleshooting this issue.
Happy stepping and stay safe.
Best Answer12-03-2020 11:55
12-03-2020 11:55
09:49
07:41
12-07-2020
09:49
07:41
@TaniaD67 thank you for the update.
At this point I suggest you follow the instructions you will get from our Support team and let them know if they work or not. Hopefully they will be able to get you back on track as soon as possible.
Keep me posted.
