01-16-2020
21:04
17:47
01-16-2020
21:04
17:47
Can't change clock face on charge 3. Click on clock and keep getting message asking if blue tooth is turned on. Google pixel 2, Windows 10 PC
01-17-2020 07:20 - edited 06-21-2024 04:07
Hi there @NJJones, welcome to the Community Forums. Thanks for the details provided. I'll be glad to help you.
In this case I'd recommend to restart your Charge 3. Then, change your clock face by following these steps:
About using Windows 10 to change clock faces, you need to use the Fitbit app on a compatible device from this list. With your computer running Windows 10, you will be able to sync but it is not possible to change clock faces; since it will need the correct Bluetooth connection.
Give this ago and let me know the outcome, I'll be around and glad to continue assisting you.
01-17-2020 20:01
01-17-2020 20:01
01-18-2020 10:07 - edited 06-25-2024 08:55
Great! 😊 I'm glad to hear that all is working now @NJJones.
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted!
08-22-2020 12:50
08-22-2020 12:50
None of the available clock faces are compatible with the Charge 3. It is different than 3 weeks ago when I was able to change it . That is not on the app now
08-25-2020 18:13
08-25-2020 18:13
agreed as i have the same issue as of today (aug 25th) tried everything & the kicker ?? it's brand new !! got it aug 25th & still can't change the clock faces !!
