01-16-2022
19:27
15:58
01-16-2022
19:27
15:58
After updating fitbit app.. I'm unable to change or update my clockface in charge 4
01-29-2022 06:13 - edited 04-20-2024 06:38
Hi there, @akhilssyam. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Charge 4.
If you haven't done so, I'd recommend trying the following steps:
Hope that helps.
01-31-2022 04:32
01-31-2022 04:32
Hi,
I'm experiencing similar issue with my new Charge 4 - only allow 2 clock faces options, M-Tumbler and Retro Double, the rest has the Labels as "Not Available" (even the original face, I think Totem, is not available once I changed it to one of the available faces). The software is up to date (I was able to make clock face changes with my daughter's Charge 4 watch).
Also, the Settings on the watch is unresponsive (after pressing the button there's no changes to the screen then after a few seconds it goes black and pressing the button again will only make a "buzz" sounds with no change to the screen. I'm able to access all the other options on the watch even though the weather button takes longer to respond compares to all the other options.
