Can't connect Charge 2 to Samsung S21
Just purchased the new Samsung S21 Ultra phone. I couldn't sync my data today, so followed suggestion to delete device and activate on the phone. Now the devices won't pair. The phone can't see the Charge 2.
3 REPLIES 3
@NanaSharon Welcome to the Fitbit Community!
Let me help you with this and thank you for troubleshooting this issue. I suggest you clear the link between your phone and your tracker by doing the following:
  1. Go to your phone's bluetooth settings and remove all devices listed there.
  2. Restart your phone and restart your device
  3. Check that no battery saving app/feature on your phone is affecting your Fitbit app.
  4. Also, on an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
  5. You can find troubleshooting instructions here.
Hope this helps.
Alvaro | Community Moderator
Same here. No luck here. Had to sync to my son's phone to fix the clock. 😒
Welcome to the Fitbit Community, @acon815. I'm sorry to hear you had to sync your Charge 2 with your son's phone to fix the clock.
Please let us know which Fitbit do you have and your phone's model.
Keep on visiting the forums.
