05-16-2022
04:38
14:29
05-16-2022
04:38
14:29
Hi,
I'm trying to restart (delete all) of my weight data in the FitBit app however, It won't let me delete the last entry.
Is there any reason why I can't delete the last entry?
I've connected the app / fitbit account to my scales and have checked that it's syncing correctly and all good there. I just want to delete this last old datapoint so I can have my first reading sync tomorrow when I weigh myself with the scale
05-16-2022 10:52
05-16-2022 10:52
Hello @abc123efg456
Deleting your weight is usually as easy as opening the Fitbit App, tap your weight tile. Locate the weight you want to lose, place your finger on it and slide to the left. A delete button should appear. Not sure why yours isn’t deleting. Have you tried deleting it here on the online dashboard? Tap Dashboard at top of your screen then tap log at the top. Next tap weight. Find the weight you want to delete and tap the trash can beside it.
😃 Hopefully this deletes that pesky stubborn one that just doesn’t want to leave. Please let me know how it goes and if I answered your question.
05-16-2022
19:05
09:05
05-16-2022
19:05
09:05
@SunsetRunner , It's always nice to see you here. Thank you for your input.
@abc123efg456 A warm welcome to the Community! Thank you for your message.
Just wanted to jump in and add something to MegaBite 's info.
Are you in the mittle of a food plan in the Fitbit app?
If so this might cause, that you cannot delete the original weight from when the plan started.
In that case, just add a weight to match your goal weight, so that the plan finishes, and then you'll be able to delete the measurements you want to.
Hope this helps too.
