01-05-2019
01:56
14:31
01-05-2019
01:56
14:31
I found it really difficult to end my swimming activity earlier so the times ran on for additional time that I want to amend. I have searched the forum, found a solution of sorts but not quite. I have found the activity but the help says I can amend using the pencil icon, there isn't one, only the trash. Any ideas? Thanks.
01-06-2019
04:51
08:13
01-06-2019
04:51
08:13
A warm welcome to the Community @lawmarsh.
Thanks for troubleshooting this activity issue by yourself. It's weird to hear that you can't edit your activity, can you please provide me with some screenshots of this? In the meantime, I recommend deleting the activity and manually enter it.
Hope to hear from you soon. ![]()
Best Answer10-14-2019 22:45
10-14-2019 22:45
Same! Did you get it solved??
Best Answer10-15-2019 00:58
10-15-2019 00:58
Best Answer09-18-2020 07:15
09-18-2020 07:15
This seems to still be an issue for me. I also can't edit my swim activity. Because I was doing some kickboard work (i.e. leg workout), the distance is off, therefore the entire workout is off -- by about 500 yards - which is not nominal. The only option I have is to delete the activity. I can't edit it.
10-13-2021 11:06
10-13-2021 11:06
Same - cannot edit on Charge 5.
