07-08-2022
20:55
10:28
AndreaFitbit
07-08-2022
20:55
10:28
AndreaFitbit
How do I get the 4 digit pairing code? Do I look on my tracker for the code? And by tracker do you mean my old fitbit? I am replacing my old fitbit because the display on the fitbit does not work. I can only see my fitbit information through the app. So how do I get a pairing code so I can replace the old fitbit that has a bad display?
Moderator edit: updated subject for clarity and format.
07-09-2022 11:02
07-09-2022 11:02
@Brenring You added on to an old thread. I apologize if I am misreading your post. It sounds like you want to set up a new device. The Fitbit app takes you through the steps after you tap on your profile image, then +Set Up a Device. The tracker code will be on the new tracker.
Laurie | Maryland
07-09-2022 11:02
07-09-2022 11:02
Laurie | Maryland
07-11-2022 15:33
07-11-2022 15:33
Thank you for your quick response. Sorry about posting on an old thread. I can never figure these forums out but I was desperate for help. Your answer helped me pair my fitbit! Once I looked on the new Fitbit tracker and held my old tracker away from my computer the code popped up and I was able to pair my device! Thanks so much!
07-12-2022 10:31
07-12-2022 10:31
Thanks for getting back to us and for sharing your set up inquiry @Brenring. I moved your posts and created a new thread in order to keep our community organized.
I'm glad to read that the steps that @LZeeW shared with you worked and that you're back on track.
Have a nice day and keep on visiting the forums.
10-22-2022 09:58
10-22-2022 09:58
Hi it's my tracker I haven't got a new tracker for some reason I can't sync my tracker so I need to put the 4 digit number so I can start syncing.
Best Answer10-22-2022 10:04
10-22-2022 10:04
Welcome to the Fitbit Community, @Lawrie123. I'm sorry to hear you haven't been able to get the 4 digit code on your Charge 2.
Please follow the instructions of: Why can't I set up my Fitbit device?
Catch you later.
Best Answer10-22-2022 11:03
10-22-2022 11:03
Still can't sync my charge 3 I need my 4 digit number how do I find it.
Best Answer10-22-2022 12:34
10-22-2022 12:34
Hi @Lawrie123 did you follow the directions from the Fitbit Moderator above?
10-25-2022 07:14
10-25-2022 07:14
Thanks for getting back to us @Lawrie123, @Odyssey13. I´m sorry to hear you still can´t sync your Charge 3 @Lawrie123.
Please follow the instructions on my previous post.
Thanks for your assistance @Odyssey13.
Catch you later.
