01-04-2017 16:52 - last edited on 09-09-2020 10:13 by MatthewFitbit
When i try to sync my charge 2 to my phone, it says tracker not found. All the settings are turned on to sync and I've restarted it and nothings working. It's new and had been working fine until today.
02-25-2017 16:36
02-25-2017 16:36
Thanks it worked. Also last week when doing challenges it would say less steps done then on dashboard. What causes that to happen?
02-25-2017 17:09
02-25-2017 17:09
Thanks! Problem solved.
02-26-2017 19:13
02-26-2017 19:13
It worked only for a short time. I had to do the reset a few times today. Right now it is working.
02-27-2017 04:09
02-27-2017 04:09
Thank you, I had the same problem and it worked!
02-27-2017 04:37 - edited 02-27-2017 07:00
My cousin told me to. Clean the connectors with alcohol too. And that helped.
03-12-2017 14:29
03-12-2017 14:29
I have tried all of the suggestions provided with no success. Any other ideas?
03-12-2017 14:56
03-12-2017 14:56
Not knowing what you've tried, I know you tried what you've seen, I'm not sure what hasn't been tried.
Restarted the phone?
Shutdown the phone?
Restarted the tracker three times?
Upgraded the app?
Removed the tracker from the phones Bluetooth screen?
03-12-2017 15:02
03-12-2017 15:02
10-15-2017 12:16
10-15-2017 12:16
Thank you, it worked.
11-12-2017 18:49
11-12-2017 18:49
This worked for mine! Thanks, Rich_Laue!
01-11-2018 04:33
01-11-2018 04:33
same here
01-05-2019 21:47
01-05-2019 21:47
This is typical of my experience. Works for two or three days then won't sync and the app has to be totally uninstalled. Crappy.
11-08-2019 18:34 - edited 11-08-2019 18:35
I tried everything suggested. The only thing that worked was turning my phone completely off and then on again. I didn't have to do anything with the FitBit itself. Finally discovered this after a good hour of playing around with it and reading and trying suggestions! Oh well... All is well that ends well.
