04-30-2021
22:28
04:01
WilsonFitbit
04-30-2021
22:28
04:01
WilsonFitbit
I've had this fitbit under a year. I've tried everything I've read on this forum.
Turned blutooth on and off
Turned the phone on and off
uninstalled and reinstalled the app
force stop the app
cleared the user data
Should I just reboot the device?
05-01-2021 04:08
05-01-2021 04:08
Hello @kpglenn. Welcome to the community forums!
Thank you for the detailed information and for the troubleshooting steps you've tried prior to posting. Regarding your question, you can restart your Charge 3 by following the instructions provided in this help article. If that doesn't work, I recommend performing a long restart by following the steps below, please note that a long restart is different than the basic one mentioned in the link above.
On a side note, looks like you've followed most of the troubleshooting steps but make sure you've covered all of the instructions from this link: Why won't my Fitbit device sync?
Lastly, make sure that the Fitbit App installed on your mobile device is up to date.
Hope this helps.
Best Answer05-01-2021 06:20
05-01-2021 06:20
I’ve got the same issue! Tried all the resets and nothing! Is it a Fitbit issue today 🤷🏻:female_sign:
05-01-2021
07:52
04:55
WilsonFitbit
05-01-2021
07:52
04:55
WilsonFitbit
I logged off and back in again and mine is working again 😊
Moderator edit: format
05-02-2021
09:51
04:56
WilsonFitbit
05-02-2021
09:51
04:56
WilsonFitbit
Mine won't show the battery icon after 15 seconds
It also stopped doing screen wake
Moderator Edit: Merged posts
Best Answer05-03-2021 05:06 - edited 05-03-2021 05:07
Hello @Tracylovesbeer. Welcome to the community forums. @Tracylovesbeer It's great to see you around.
Thank you for the information and troubleshooting steps you've tried. @EvieF I'm glad to hear that your Charge 3 is now working again.
@Tracylovesbeer If your Charge 3 isn't turning on when you move your wrist toward you, please make sure that the DND (Do not disturb) option isn't enabled on your Charge 3. Please note that when the do not disturb setting is on, notifications, goal celebrations, and reminders to move don't cause the tracker to vibrate or the screen to turn on. You can't turn on do not disturb and sleep mode at the same time.
If that is not the case and you can't still perform the restart or long restart mentioned on my post above, then I recommend contacting our Support Team for further assistance. You can contact them through chat or over the phone. Click here to get connected.
See you around.
