Can’t locate alarms since update
Since the recent update, I can’t find how to set an alarm, any solutions?
5 REPLIES 5
On the main "today" tab of the dashboard, select your profile image at the top left of the screen, then select your fitbit. You will then be on the device settings where you'll find the alarms
Thank you for your help 😀
Sent from my iPhone
Hello, can you explain what you mean by “find your Fitbit”?  When I go to my account page it only allows me to view my profile and set goals.  TIA
@fthisapp when I go into the account section of the app on my phone by selecting my profile there is a section of the page called Devices. In there I see a picture of my Aria 2 and a picture of my Versa showing the last synced time and the battery level. If I then select the Versa image I go to the device settings.
Thank you- I had to re-sync my Fitbit because my device was missing all of a sudden!
