03-24-2018
19:03
18:54
03-24-2018
19:03
18:54
Device didn't sync so I removed it from app and tried the pair it again however it goes as far as finding the device pairing the 4 digits but then it just keeps showing that it is connecting. Not sure what to do have restarted tracker and phone and reinstalled the app
11-03-2019 01:53
11-03-2019 01:53
I tried every solution suggested, the one that worked for me was to force a stop, restarted and bingo !
11-08-2019 11:53
11-08-2019 11:53
Hi,
I've tried all of these steps and i am still unable to get my charge 2 to pair. Is there something else i can try?
Any advice would be great.
11-21-2019 14:08
11-21-2019 14:08
Same craic here tried all the fixes. A pure cod won't be getting one again
03-21-2020 18:04
03-21-2020 18:04
im trying to pair my fitbit charge 2 again on my lg g6 android phone and its not working and i am feeling super pissed off and super frustrated and overwhelmed and panicking that its not pairing anymore!
08-07-2020 14:52
08-07-2020 14:52
If your Charge 2 tracker keeps failing to pair back after entering the PIN and nothing else works then please check if the fix shown in https://www.youtube.com/watch?v=YRWh3d3wrYc helps !!!
In short, assuming that the pairing is failing due to an incompatible android version (due to android updates), the goal is to ...
1. First, try to pair your tracker with your account in Fitbit app on some other mobile with compatible android version.
2. If pairing is successful then sync the tracker and the app.
3. Once syncing is done, unpair your tracker from the Fitbit app.
4. Now try to pair your tracker with Fitbit app on your original mobile and see if it works.
09-28-2020 13:53
09-28-2020 13:53
Thanks! This is what solved it for me! glad that I had some old phones laying around!
11-24-2020 12:45
11-24-2020 12:45
I have the exact same problem as the original poster and I tried all of these steps multiple times and my charge 2 still will not re-connect with my android phone, It was fine up until a week ago and just this morning I realized it wasn't syncing. Are there any other steps to try?
11-24-2020 13:46
11-24-2020 13:46
Add my voice here.
Sync keeps falling.
11-30-2020 09:52
11-30-2020 09:52
I'm also having this problem and the suggested steps won't work. I'm on Android 11, in case that helps.
