08-13-2022
09:27
12:54
AndreaFitbit
08-13-2022
09:27
12:54
AndreaFitbit
Hello,
I have purchased a FitBit second hand over. However I am trying to pair my fitbit with my iPhone and it is not working. I get a code which I then enter for in my iPhone app from FitBit and then get the message "a problem has occurred ". I have also tried it on my Windows laptop and that doesn't work either. I can't get my Fitbit connected to my iPhone and I hope you can help me.
Moderator edit: format.
08-13-2022 10:07
08-13-2022 10:07
First I would make sure there are no other bluetooth devices around; then try again and see if get exact same result; sometimes just takes a few tries but seems like you got past the usual sticking point.
Then if any family member or friend with smart phone could try it, see if get same result.
Then contact Help.
Don't have any basis for this, but wonder if person who sold it 2nd-hand had gotten a refund for it without returning it so fitbit disabled it - just idle speculation.
08-13-2022 13:57
08-13-2022 13:57
Hello,
Thanks for your respond back, but unfortunately it still doesn’t work. The person is a family member and they say it’s not the case. Is there something else I can do?
10-28-2022 02:30
10-28-2022 02:30
Go to the Bluetooth settings on your phone and check if your tracker is on the list of paired devices. ...
Restart your phone.
Plug in your tracker and make sure it's charging.
Make sure there are no other Bluetooth devices around that might interfere with the process.
Set up your tracker as a new device:
Regards,
Will
