10-06-2019
10:37
12:16
10-06-2019
10:37
12:16
One last try to get this Charge 2 working so Im looking here for help.
I got a new phone (Android) and wanted to get my fitbit off the old ipad and start using the phone.
The app is also ised by my wife so I selected 'Forget this device' on the ipad.
Now I realise this affected the app on my phone, no problem just re-add? Wrong.
Steps taken to resync (many, many times...)
Restart fitbit;
Restart app;
Restart phone;
Hard reset Fitbit;
Remove App;
Restart phone;
Re-install App;
Try another device (see below);
Crazy thing is using a friends fitbit app, I can see and connect to my fitbit (I go as far as getting the bluetooth PIN on the fitbit face before cancelling'
So this proves the fitbit is still good.
I imagine by 'forgetting' the fitbit, the app adds the fitbit to a blacklist and probably syncs this with your online profile. It appears this is not reset when you remove the app (hence my profile theory) All attempts from here have not worked. Nine months of data are no longer accessible.
Can anyone shed any light on this flaw in the software. I have read many threads where this is causing a problem. Can I suggest an 'unforget device' option in the software? That would sort it.
MTIA. Andy.
10-07-2019
08:30
07:15
10-07-2019
08:30
07:15
@Andeebee Welcome! It's good that the community is growing!
Let me help you setting up your Charge 2 and thank you for troubleshooting this issue. There isn't any block on your account and you should be able to setup your tracker again on it. As you mentioned you got the prompt on a friends account. Most importantly which phone are you using? Is it compatible? You can try the following:
If the issue persist try using your friends phone but log into your account there. Setup the tracker and try to use your own phone just to sync it.
Let me know how it goes.
