03-15-2019
09:51
10:12
AndreaFitbit
03-15-2019
09:51
10:12
AndreaFitbit
Hi,
I can barely read my Fitbit Charge 3 display in a dark room. It’s got progressively worse to the point the screen is near enough black constantly. I’ve tried going via the settings App to change the screen brightness but it’s made no difference. Is there anything else I can do? None of the discussion so far seem to have provided an answer and mine is at the point I can’t even read it indoors!
Moderator edit: format.
03-23-2021 14:38
03-23-2021 14:38
My Charge 3 has the same problem. Do any of the Fitbit models have a consistently brighter screen?
Best Answer03-23-2021 15:58
03-23-2021 15:58
Best Answer03-23-2021 16:04
03-23-2021 16:04
Best Answer03-23-2021 16:11
03-23-2021 16:11
Best Answer04-02-2021 06:07
04-02-2021 06:07
Best Answer04-02-2021 06:17
04-02-2021 06:17
Best Answer04-02-2021 13:07
04-02-2021 13:07
I had to argue and push FitBit a little but they did finally replace my Fitbit and the new one has worked quite well for some time now.
Best Answer04-02-2021 14:57
04-02-2021 14:57
Best Answer04-03-2021 06:08
04-03-2021 06:08
Best Answer04-03-2021 06:10
04-03-2021 06:10
Best Answer04-03-2021 07:23
04-03-2021 07:23
Best Answer04-03-2021 12:19
04-03-2021 12:19
I just fixed mine. Scroll to right to settings. Click on it. Brightness may say dim. Click on it and you get choice of brightnesd normal which is where you click.
Best Answer04-03-2021 15:23
04-03-2021 15:23
Best Answer04-03-2021 16:39
04-03-2021 16:39
Best Answer04-03-2021 16:44
04-03-2021 16:44
Best Answer04-03-2021 16:49
04-03-2021 16:49
Best Answer04-03-2021 17:23
04-03-2021 17:23
Best Answer04-03-2021 18:54
04-03-2021 18:54
Best Answer04-04-2021 03:47
04-04-2021 03:47
Best Answer04-04-2021 03:56
04-04-2021 03:56
