03-29-2017
08:18
09:49
03-29-2017
08:18
09:49
I have had my Charge 2 for several months and change my wristband several times a week. Recently I have had trouble removing the bands (both sides). I have even resorted to using needle nose pliers to assist since I have long nails. Now I can't get one side off even using the pliers. Any suggestions?
03-30-2017 08:07
03-30-2017 08:07
After looking at the Charge 2 itself, I found that on the side where the band attaches the little square had rough edges on the bottom. I spoke with Customer Service and sent them a picture. They are replacing it.
03-29-2017 09:24
03-29-2017 09:24
@BarbDayton Thanks for joining us! This shouldn't be happening, is this the original wristband that came with your tracker or a third party one? Have you noticed any damage in the area that latches to the tracker? I suggest you use a screwdriver to help remove the wristband. If the issue persist please share a picture of the wristband and the area that is giving this issues, you can also Contact Support if it is the original wristband or contact the vendor if it is a third party one.
Let me know how it goes!
03-29-2017 10:21
03-29-2017 10:21
I don't know how to attach a photo to this message but looking at the fitbit itself, it appears that the little "square" on the tracker is rough and that could be why the strap won't detach. (I did get the strap off). I am going to contact Customer Service.
03-30-2017 08:07
03-30-2017 08:07
03-30-2017 08:37
03-30-2017 08:37
@BarbDayton Happy to hear that support is sending you a replacement and thank you for letting us know what you did when talking to them (sending pictures) as this may help other members in the same situation.
I'll be around!
04-17-2018 14:01
04-17-2018 14:01
I followed directions and cannot get the wrist bands off to change for new ones I ordered. Does anyone have a diagram? I need help, please!
04-18-2018 04:43
04-18-2018 04:43
@anita-marie Welcome! It's good that the community is growing! Are you trying to remove the original wristbands or a third party ones? To remove the wristbands please do the following:
04-18-2018 05:02
04-18-2018 05:02
05-03-2018 08:59
05-03-2018 08:59
@anita-marie glad to hear that you were able to remove your Charge 2 wristband. Hopefully you can now personalize it wearing the one you most like or for the appropriate occasion.
I'll be around!
08-25-2018 13:07
08-25-2018 13:07
I have had problems with one side of the wristband from day one. I detatched the straps to put on a cover over the face to protect it from scratching but one side wouldn't come off without a lot of difficulty. Now I can't get the one side off at all. Somewhere above it suggested removing it with a screwdriver. How do I do this? Pry it off? This is very annoying.
09-04-2018 09:22
09-04-2018 09:22
@redgate A warm welcome to our Community! Sorry to hear that you can't remove the wristband from your tracker. You can try using a screwdriver to apply some force to the metal tab on the wristband but don't need to force or break it (check the image for reference). Also is this the original wristband that came with your tracker? How does the protector affected the connection between the tracker and the wristband?
09-04-2018 09:56
09-04-2018 09:56
03-24-2019 11:54
03-24-2019 11:54
Hie, my Charge 2 band has become loose on one side, how can i get this fixed
11-25-2022 09:38
11-25-2022 09:38
Hello I'm getting trouble in removing my fitbit charge 2 strap it's not removing very easily it's very hard to remove any suggestions
