03-22-2019
01:52
16:45
03-22-2019
01:52
16:45
Tried to remove an "old" phone after upgrading to newer phone through "Manage Account". Both phones are listed, but I want to remove the old phone. There is no option to "Remove" when I select the device while using a laptop.
03-22-2019 14:31
03-22-2019 14:31
I see a "Revoke Access" option.
Also try breaking the bluetooth connection on your old phone.
03-24-2019 11:13 - edited 03-24-2019 11:14
@dg1890 I hope you're doing well!
Thank you for your inquiry. Where are trying to remove the phone from? Could you share a screenshot of this. The more information we have the better we will be able to assist you. I also want to clarify that the tracker is associated with your Fitbit account not with a particular phone although you can link their bluetooth as this helps with the syncing process.
@JohnnyRow thank you for your help in this thread.
I look forward to your reply.
