12-07-2018 10:25 - last edited on 11-17-2020 14:34 by MatthewFitbit
Touch control to scroll face not working!
02-16-2019 06:10
02-16-2019 06:10
My screen froze this morning and wouldn’t scroll, and I don’t have my charging cord with me, so couldn’t use that to reset it, but I saw your comment about switching watch faces, and tried that from the Fitbit app on my phone, and it worked! Thanks for posting that!
02-16-2019 06:16
02-16-2019 06:16
So glad it worked for you! Enjoy your day😊
02-16-2019 09:06
02-16-2019 09:06
02-16-2019 10:49
02-16-2019 10:49
I am having the same issue. I just set up my charge 3 yesterday afternoon/evening. Things were working well yesterday, but it must have gotten messed up overnight. I can no longer scroll or tap to change displayed stats. When I hold the side button, I get to a screen that has Screen Wake and Notifications on it, but I can't interact with that screen at all. I have done both the short reset and long reset multiple times, as well as switching the clock face multiple times.
02-16-2019 10:55
02-16-2019 10:55
It sounds like you need to get a refund. It has always worked for me when I do a hard set of 15 seconds followed by a clock face change. Fitbit should be ashamed for selling something that needs so much work. I hope you figure this out.
02-16-2019 13:01
02-16-2019 13:01
I'm having the same issue. My fitbit vibrated when I was out to let me know I'd hit the 10000 steps but the screen wouldn't scroll. When I got home I synced it with my phone and tried charging it. It vibrated when connected to the charger but still wouldn't show anything but the main screen on the displayed. I'll try the suggestions but I've only had it since christmas so a new device shouldn't be having issues.
02-16-2019 13:23
02-16-2019 13:23
I agree, something that is only a couple of months old should not be having the issues that these charge 3s are having. Do a hard set then change the clock face to any one-you can always change the clock face back to the one you like after. Hope it works.
02-17-2019 09:22
02-17-2019 09:22
I had the same issue with not being able to scroll. I tried this fix, and it worked, but now I can't sync to my phone. Please help!
02-17-2019 09:30
02-17-2019 09:30
I’m really sorry to hear that. I have no solution to your problem because I’ve not run into that. Try turning the all day sync toggle to on or off depending on what you have it on currently. I’m only guessing at possible solutions. I know on other apps that have given me problems switching the toggle button has helped. 🤷:female_sign:
02-17-2019 10:11 - edited 02-17-2019 10:14
I did a live chat yesterday. I had to send in a video to show my fitbit was not working correctly. My ticket was supposedly escalated, but I haven't heard anything back yet.
In case someone from fitbit sees this: Syncing, phone notifications and tracking still continue to work. Tapping turns the screen on, but tapping doesn't scroll through the stats, and swiping doesn't work at all.
Live chat link: https://help.fitbit.com/?cu=1
02-19-2019 13:23
02-19-2019 13:23
Okay, since I am away from my charger at home I tried the suggestion of changing the clock face to unfreeze my Charge 3. That worked. I don't like that this happens, but at least I have a fix on the go.
02-20-2019 16:59
02-20-2019 16:59
Thank you putting on charger worked
03-27-2019 11:42
03-27-2019 11:42
I agree, this is happening right now, but I cant reset because my charger is at home. I don't normally carry it. I just got this for Christmas, this is the 2nd issue I have had.
03-27-2019 12:01
03-27-2019 12:01
03-27-2019 14:51
03-27-2019 14:51
Im having the same problem - can only get the time screen. I have had this Fitbit Charge 3 for about 2 months and it is my third one since beginning of January.
03-28-2019 17:57
03-28-2019 17:57
03-28-2019 18:38
03-28-2019 18:38
04-20-2019 16:51
04-20-2019 16:51
Yes this worked...
04-20-2019 20:23
04-20-2019 20:23
Exactly! I’d say there is a design flaw for sure!
04-21-2019 15:24
04-21-2019 15:24
Hi @Theresared716, @Pentricia, and @KarinP, it's great to see you around. @Sheila_D, @Orchardmudtwin and @Ilovestbernards, welcome on board! Thanks for sharing your experience with your Charge 3 devices and I'm sorry for the delay in my response.
@Sheila_D, @Pentricia, @KarinP and @Orchardmudtwin , I'm glad to hear that your devices are back on track after trying the restart and changing the clock faces. You did an amazing job, and thanks for the tip!
@Theresared716, could you please confirm whether you have tried restarting your device and changing the clock face?
@Ilovestbernards I understand your position and appreciate your feedback towards the Charge 3. This device was designed to motivate you towards your daily activities and while it should continue working, let me know if you face this situation again so I can give you a hand and bring a solution for you.
I'll be around if you need anything else.
