09-28-2020 04:22 - last edited on 09-28-2020 20:13 by LiliyaFitbit
I can’t see my watch face/screen when outside anymore. It only seems to work when inside but not with light in it. Why csn o no longer see the screen outside and can it be fixed?
09-28-2020 09:51
09-28-2020 09:51
Check you are not in Sleep Mode, keeping the display dim.
09-28-2020 10:18
09-28-2020 10:18
Since the last update I have had the same problem. Occasionally I feel like it is working correctly, but other times, even in the shade I can't see what time it is. I have tried resetting, changing my clock face, making sure brightness was set to normal, ugh
10-03-2020 18:57
10-03-2020 18:57
Sleep mode is not on
10-03-2020 18:58
10-03-2020 18:58
Mine is the same
10-03-2020 19:04
10-03-2020 19:04
I have the same issue. At first I thought it was just outside but over the past several weeks, the display has dimmed more to the point where it is almost unreadable inside. I have adjusted the display settings several times but Auto makes the display unreadable almost to the point I cant change it back. I leave it on Normal now. Dim is unviewable. There are also sections of the display that are dimmer than others resulting in a gray rather than white text.
10-04-2020 09:40
10-04-2020 09:40
Same here. Reached out the other day to someone from fitbit and no replies. Very frustrating. Purpose is to track activity, I do my activity outdoors! I have tried restarting, changing the face display and anything else I have found as suggestions... Still nadda..... Might have to stop being a faithful fitbit user....
