01-27-2019
10:01
17:54
01-27-2019
10:01
17:54
On calls and texts I am getting a vibration but no visual. I disconnected then added it as a new device but that hasn’t helped. Ideas?
01-28-2019 04:23
01-28-2019 04:23
Hey @ToniLy, let me give you a warm welcome to the Community! Thanks for trying that. Besides setting up your Charge 2 as a new device, I'd like you to take a look and follow the troubleshooting in this help article: My Fitbit device isn't receiving notifications from my phone.
Let me know how it goes!
01-28-2019 04:23
01-28-2019 04:23
@ToniLy It's great to see that you've visited the Fitbit Community! Sorry to hear that you can't see your notifications on your Charge 2. Which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
01-29-2019 06:49
01-29-2019 06:49
Hi. I use a 7+ and I did what you suggested. Now sall metimes it works and something I have to press the button to see the message. So it’s obviously synced but doesn’t always appear. Strange.
01-29-2019 06:52
01-29-2019 06:52
I did try all those things. I have an iPhone 7 Plus. Just tested this morning and it worked. Thanks for your help.
01-29-2019 10:21
01-29-2019 10:21
Sounds great that your Charge 2 is working fine after trying the suggestions that my friend @AlvaroFitbit posted above. We appreciate the update. 🙂 If you have further questions or comments, let us know.
Have a great day!
