02-04-2019
18:54
11:25
02-04-2019
18:54
11:25
No matter what display brightness setting i can’t see the charge 3 display while outside. What can be done to fix this. My current display brightness is Normal, that seems to be the brightest, but it’s totally useless while outside. Help!!!
09-15-2019 08:14
09-15-2019 08:14
I have this problem too - it is ok inside but I can't view it at all outside
09-17-2019 02:09
09-17-2019 02:09
Same here - can't see the display in the slightest brightness outside. I use mine as a watch inside - can't see the display for running outside and can't auto track swimming.
09-17-2019 06:22
09-17-2019 06:22
There's no fix for this, so contact Fitbit Support and arrange a replacement.
09-17-2019 06:39
09-17-2019 06:39
12-28-2019 02:16
12-28-2019 02:16
I have had a Fitbit Alta for a few tears and have found the screen really difficult to read when outside. I have just been bought a Charge3 for Christmas and am concerned that this also has the same problem. Please can you advise before I use it. Thank you.
12-28-2019 03:15
12-28-2019 03:15
12-28-2019 03:43
12-28-2019 03:43
03-28-2020 01:19
03-28-2020 01:19
I’m having this problem...the screen has been fine for a year’ish but now can’t see anything outside ? Tried all the suggestion to no avail.
03-30-2020 08:07
03-30-2020 08:07
The issue does not seem to have ever been resolved. I went through Fitbit customer service to try to fix. They sent me 2 other replacement units. I have given up. I just wear my Fitbit now to track my steps since it is useless as any type of training watch for outside.
03-30-2020 08:31
03-30-2020 08:31
Best Answer03-30-2020 08:39
03-30-2020 08:39
04-12-2020 13:35
04-12-2020 13:35
thank you so much! I've been having this problem for a while now and your suggestion just totally fixed it!
Best Answer04-25-2020 19:12
04-25-2020 19:12
Ran a social distance 5K today and my Charge 3 did not track. I cannot see the display outside and was swiping and pressing from memory. Couldn’t turn in my results. I’m over not being able to use the display outside.
Best Answer05-21-2020 19:38
05-21-2020 19:38
Display is still not visible when I am outside
05-26-2020 08:22
05-26-2020 08:22
Has this issue been rectified? I’m considering purchase of two charge 3 trackers...
Best Answer05-26-2020 09:14
05-26-2020 09:14
Not sure if this has been said yet, but I believe the sleep settings will affect the brightness of the unit(even when the brightness is set to brightest). If you turn off the sleep monitoring the screen should be at it's brightest..
05-26-2020 11:34
05-26-2020 11:34
It has not been resolved. Every time I reached out to Fitbit I would get an email saying they are working on the issue.
Best Answer05-26-2020 11:45
05-26-2020 11:45
Thanks So Much!!!
Best Answer05-26-2020 11:49
05-26-2020 11:49
Thank You
Best Answer05-26-2020 12:04
05-26-2020 12:04
I’ve set the intensity to “auto” as suggested, and it does help in the bright sun. But when running, it’s still so dim it’s impossible to read. Personally I would not go this route again, especially if you’ll be using it outdoors a lot.
