Can't see the Charge 3 screen
the screen on my watch is indistinct. I can not see what time it is. The batteri i ok and it syncs ok.
1 REPLY 1
@Mussing I hope you're doing well!
For screen issues we recommend a restart that you can try by doing the following:
  1. Plug the charging cable into the USB port on your computer or any UL-certified USB wall charger.
  2. Clip the other end of the charging cable to the port on the back of the tracker. The pins on the charging cable must lock securely with the port.
  3. Make sure the button on your tracker is aligned with the button opening on the charging cable. You’ll know the connection is secure when the tracker vibrates and you see a battery icon on your tracker’s display.
  4. Press and hold the button on your tracker for 8 seconds. Release the button. When you see a smile icon and the tracker vibrates, the tracker restarted.
  5. Disconnect your tracker from the charging cable.
Hope this helps.
Alvaro | Community Moderator
