08-15-2021
06:07
04:10
WilsonFitbit
08-15-2021
06:07
04:10
WilsonFitbit
I began having problems syncing my Charge 3 via Bluetooth so tried to set up a replacement one. The setup goes smoothly until the Fitbit tries to update the firmware. It starts off with the progress bar and then changes to a "!" in a circle, then goes back to the initial fitbit.com/setup screen while the app stays stuck on Downloading at 1%. I have had this issue over and over and I can't seem to fix it and actually get the Fitbit set up.
08-16-2021
04:12
07:59
08-16-2021
04:12
07:59
@emilyyy29 It's great to see that you've visited the Fitbit Community!
Thank you for troubleshooting this issue. Please try the following:
Hope this helps.
04:13
07:59
08-16-2021
04:13
07:59
Hello @emilyyy29. Welcome to the community forums.
Thank you very much for the detailed information and for the troubleshooting steps you've tried prior to posting. At this time, I noticed that you have contacted our Support Team and they will be working on your case as soon as possible. I appreciate your patience and I'd recommend keeping an eye on your inbox since they should get back to you soon.
See you around.
