01-25-2019
08:51
13:05
01-25-2019
08:51
13:05
My notifications are turned off yet my texts continue to ping and show on my watch. How do I completely disable?
01-26-2019 07:20 - edited 01-26-2019 07:22
It's nice to see you around here @courtneyld! If you want to turn some of your notifications, I recommend doing the following:
Also, if you're on Android phone, on the device settings scroll down and turn off the switch for Keep-Alive Widget. That should turn off the notification.
I hope this helps, let me know the outcome. ![]()
Best Answer01-26-2019 08:06
01-26-2019 08:06
Best Answer01-26-2019 09:43
01-26-2019 09:43
Thanks for getting back @courtneyld! Which notifications are you receiving?
Please try doing the following:
Test your tracker and let me know if you're still receiving notifications. I'll be around!
Best Answer10-01-2019 15:53
10-01-2019 15:53
I am having the same issue...ran thru steps recommended to turn off calendar and text notifications but it still continues...worked for a while then started up again...when is this bug going to get fixed?...I dont have the patience to "log out; turn off bluetooth, shut off phone, restart, etc." as this happens too frequently...how does this permanently get resolved???
Best Answer10-03-2019 13:30 - edited 10-03-2019 14:09
Hi there @kevinCG, welcome to the Community Forums. Thanks for following the tips and recommendations provided in the forums to turn off your notification.
Please make sure that Calendar Events and Tex Messages are turn off in the Fitbit app. In order to do so:
If the issue persists after following the steps above, tell your phone to "forget" your device, removing the connection between the phone and the Fitbit device.
Give this a go and let me know the outcome.
Best Answer10-03-2019 17:29
10-03-2019 17:29
Best Answer10-04-2019 09:52 - edited 10-04-2019 10:05
Hello @kevinCG, thanks for getting back.
I'm posting the images requested and the step-by-step to disable your notifications:
Let me know how it goes this time. I'll be around if you need more assistance. 😊
06-17-2020 05:32
06-17-2020 05:32
Really found this helpful, thank you very much!
