01-27-2017
02:52
10:13
01-27-2017
02:52
10:13
Scenario of Events
Is there a way of deleting my previous phone from the trackers memory?
OK now I have today’s data which is being updated ok.
I don’t seem to have any previous data.
Do people from fitbit monitor this community?
I am getting very frustrated.
Thanks
Ken
01-27-2017 05:40 - edited 01-27-2017 05:43
Thanks for stopping by my friend @Kennyx! Thks for letting me know what you've done so far!
You should connect your Charge 2 with no problem whenever your new phone is included in the list of supported devices. Have you checked that already?
After reading your post, I was wondering, what's is the standard error page you get? Would you mind sending screen shots?
Since you're trying to set it up again, make sure about the following:
Once you verify all of the above, if you keep having difficulties with the set up process, do the following:
Let me know if this finally works for you! ![]()
01-27-2017 06:44
01-27-2017 06:44
Generally setting up a new phone is easy.
First step is to turn off or move the old phone 30 feet away, no promblem here since the old doesnt work.
Next download the app and log into your fitbit account.
I believe apple has one more step, and the app will prompt you.
If you remaved your tracker, then we have to figure out why it wont sync so that we can add it back to your account. Then the app will know what tracker to sync. For troubleshooring see http://help.fitbit.com/articles/en_US/Help_article/1866/
Best Answer01-27-2017 08:04
01-27-2017 08:04
In answer to the previous post it will sync for todays data just nothing retrieved from Jan 17th to yesterday.
I restarted 3 tracker 3 times and this is what happened
No - sync todays data
last sync displayed as 16th Jan
No data in between
exactly as before
Best Answer01-27-2017 12:39
01-27-2017 12:39
Thank you to everyone who has replied and tried to help.
I have done everything that has been suggested.
Most of the help surrounds not syncing however the situation now is that it does sync and retrieve today's data but nothing between the 16th January and today.
Could someone from Fitbit please contact me because at the moment I have the most expensive step counting device in living history.
Thanks
Ken
Best Answer01-30-2017 05:15 - edited 06-17-2025 06:37
Alright, let's clear things up so we won't get lost. On January 16th you set up your tracker with no problem, next day your phone was missing. A few days later, you got a new phone which is exactly the same model than the previous one. Right?
What I need to double check is, when you got your phone and logged into your account, what did you do in the first place? Did you sync or try setting it up as a new device?
The thing is that a daily sync is recommended but not required. Most Fitbit trackers record detailed minute-by-minute data for seven days, so if you're able to sync weekly you should find all your data on your Fitbit dashboard. After seven days, Fitbit trackers can store daily totals for up to 30 days.
However, when you set up the tracker as a new device you'll loose all the previous data if you didn't have the chance to sync before the set up process. And you'll start seeing new data after completing this process, but there's no way to bring all the previous data unless you decide to manually log it.
Therefore, this is what I'd like to know.. did you sync or set up your tracker first @Kennyx?
01-30-2017 05:22
01-30-2017 05:22
Best Answer01-30-2017 05:35
01-30-2017 05:35
Hi
This is what I believe happened after giving it some thought.
I synced the new phone and got that day's data.
I looked for the previous day's (this was my experience of the app) and there wasn't any to be displayed it was then that I started to find out where it was.
I must have added the phone then.
Ken
Best Answer01-30-2017 06:00 - edited 06-17-2025 06:36
Ok, I was asking that because I had a similar experience when I upgraded my phone. I sold my previous phone, but I was waiting for the new one to arrive. I didn't have the chance to sync with other phones or even with a computer, so I didn't sync for over a week or so.
When I got my phone, I was so excited to set everything up that I made the mistake of setting up my tracker as a new device instead of just syncing it. Because of this, I lost all my previous information. This is the same when you get your tracker for the first time, sometimes because of movements or things like that, so your tracker shows information even when you haven't put it on yet. However, when you pair it to your account, the only information you're gonna see on your Dashboard will be from the day you linked it, not the previous data. I don't pretty sure is this is making sense and I don't wanna confuse you.
However, if this is what happened to you as I mentioned before, the only way to bring your data back is by manually logging it. But if this is not your case, to better understand what happened is by getting in touch with Customer Support directly so they can do a deeper investigation and see where the issue may be coming from.
In case you decide to manually log your activities, see this post of @SantiR to get the instructions for that.
You'll be in good hands!
01-13-2019 15:56
01-13-2019 15:56
Hi, did you ever find a solution? I'm having the exact same problem. I got a new phone, and it won't sync. I chatted with people at Fitbit. They took me through the standard troubleshooting, and when that didn't work, they suggested I throw out my tracker and buy a new one. What!? There's not to be a solution!
01-15-2019
08:31
10:31
01-15-2019
08:31
10:31
@noramiriam Welcome! It's great to see you around! Sorry to hear that your tracker isn't syncing with your phone. Which phone are you using? Is it compatible? You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on.
Let me know how it goes!
