Can't sync my Charge 3, it finds my girlfriend's Charge 3 instead
My girlfriend has a charge 3 and when I try and setup mine on my own account it just finds hers...I walk down the street and I can connect no problem but as soon as I’m in the house it says “looking” any help would be appreciated.
8 REPLIES 8
For setup, try moving hers further away.
But if you couldn't set yours up, I don't know what you mean that you can connect when outside;  what does "connect" mean if you couldn't get through setup?
If I take a walk down the street I can set mine up no problem. When I come back in the house instead of syncing it just says looking...
Is your girlfriend's tracker also in the house nearby?  It often helps for set-up and syncing if move other trackers further away so as to not confuse bluetooth.
Yes exactly, that’s why I have to walk down the street to set up. Is it because both are Charge 3’s?
Could try putting one in fridge or microwave while sync the other.  I don't know if it matters if it is same model.
Thanks for the input.
Sorry I couldn't be more help.
Hello @craigdarbour, welcome to our community forums! @JohnnyRow, it's nice to see you around and thanks for great input!
I was able to see that you have a case with our Support Team for this situation. Since you have received assistance from them, I suggest you to update your case if you require further assistance or if you have any additional questions about the outcome of your case.
See you around.
Wilson M. | Community Moderator, Fitbit.
