03-01-2021
20:43
03:08
AlvaroFitbit
03-01-2021
20:43
03:08
AlvaroFitbit
I want to sleep in tomorrow (day off), but I know that my alarm is going to go off at 5:25 like always. I swipe to the screen where I should be able to turn off the alarm, tap the alarm to "off", Then what?
The only way to get out of the screen seems to be two squeezes of the watch, then if I check to see if it really turned off the alarm, It didn't.
I don't want to have to delete the alarm every time I have a day off only to re-enter it. The "off" should work, but I don't know how to make it stick. Very frustrating.
03-02-2021
03:11
10:06
03-02-2021
03:11
10:06
@whateverdude It's great to see that you've visited the Fitbit Community!
Sorry to hear about this. Try restarting your tracker by doing the following:
If the issue persists then remove the alarm, save and sync (even though you do this from the tracker itself), re-enter the alarm, save and sync again to see if the feature works.
Hope this helps.
