01-20-2024
13:01
06:53
01-20-2024
13:01
06:53
Can not get my fit bit 3 off sleep mode and can not see the display of time and steps.
01-21-2024 07:03
01-21-2024 07:03
Hi there, @Hilarie. It's nice to see you around the Fitbit Community Forums. It's sad to hear that you cannot turn off the sleep mode feature on your Charge 3, I will be glad to help you!
I did have a similar issue with my Versa 2 a while ago. I know that you mentioned that you already tried turning off sleep and DND mode, but please note that DND and sleep mode can't be turned on at the same time what means that is very likely that sleep mode is turned on (which keeps DND on and the screen wake remains off). Have you tried just tapping sleep mode to turn it off? When I had this issue, I was tapping all the options because I didn't know what was going, until I just tried turning off sleep mode, and that was it, my issue got solved. Would you mind double checking that?
If the above doesn't help, please try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
