Can the Charge 2 display stay longer?
Is there a was to keep the screen visible longer. Right now it last about 2 seconds. I wear my Fitbit to work so I need it lite longer. Thank you
3 REPLIES 3
Sorry, but you cannot change that.
Hey @HG2004! Welcome aboard! Oh! No, like my friend @SunsetRunner said, this option is not available on the the Charge 2, but it could be great to have it, so we can adjust the duration, but it will definitely will consume more battery.
On the other hand my friend, since you are around the Fitbit forums, I urge you to visit our Discussions board, where you can share tips, experiences and all about a healthy lifestyle.
Have a nice weekend!
Heydy | Community Moderator, Fitbit
I'd like to add my two cents here-- the very short amount of time that the display stays up is very very very very very very very (how much emphasis can I give this) problematic. More often than not, my heart rate is not correct when I first turn the display on or use the quick display function, but if I give it a few seconds, it will update correctly. With the Fitbit, this process involves turning it back on four or five times WHILE trying to run. And when on trail runs, I'm bouncing around too much to focus on it in that amount of time, so I'm all over the place on trail while trying to screw with my Fitbit long enough just to see my heart rate. Please, I beg you, create an option to change the default display time.
