09-23-2018
07:44
15:47
09-23-2018
07:44
15:47
Anyone know if the Charge 3 is going to have that annoying bright green screen at night? Or if there's going to be a facility for turning it off? Does the Versa have the same feature?
12-31-2018 07:20
12-31-2018 07:20
I do not have screen timeout in my settings?
12-31-2018 10:43
12-31-2018 10:43
Hi @Unojohn and @Tremblay! At this time, the screen timeout is not available which is why it was removed from the user manual. If that changes we will make sure to update your existing Feature Suggestion and any Community threads asking for this feature.
I appreciate your feedback and will make sure to keep everyone informed if anything changes.
Thanks for jumping in here @Kiddo65 and @skkris! I'm glad to hear you were able to find the Screen Brigtness settings after following @Heather-S and @KAF454 recommendations.
Please don't hesitate to let me know if there's anything else I can assist you with.
01-23-2019 05:25
01-23-2019 05:25
Greetings,
I went to my settings to change the brightness but it doesn't allow me to tap on "brightness" to change. It's basically just telling me that it is on "auto".
Help! It's too dim!
01-23-2019 06:11
01-23-2019 06:11
02-16-2019 22:01
02-16-2019 22:01
Why don’t I see this on my charge three ? I am finding it low light outside I can’t see what time it is !!! And it’s not picking up when I flip my wrist - frustrating
02-17-2019 06:22
02-17-2019 06:22
02-17-2019 22:53
02-17-2019 22:53
02-18-2019 06:50
02-18-2019 06:50
02-18-2019 07:19
02-18-2019 07:19
02-18-2019 07:23
02-18-2019 07:23
03-07-2019 05:34
03-07-2019 05:34
Mine doesn't have the screen timeout option and goes off after a second or two whilst I'm trying to use it
03-08-2019 07:42 - edited 03-08-2019 07:43
Welcome to the Fitbit Community @nicoleburrus82 and @Beanie65 (thanks for the picture provided)! The screen timeout setting isn’t available on Charge 3. We removed the incorrect image from the manual.
For anything else you would like to see implemented in the future, consider visiting our Feature Suggestions board. This is a space where Community users can post features, ideas, and suggestions that they'd like to see in future Fitbit products, accessories, and software and top-voted suggestions get relayed to our product team for review.
You can learn more about how Fitbit decides what suggestions get released in our FAQs.
I was making some research and was able to find this idea asking for the same:
Thanks so much for helping out my friend @Kiddo65!
I'll be around if you need further assistance!
04-17-2019 10:09
04-17-2019 10:09
where is the "settings" app located on my charge 3 tracker. I'm trying to change the brightness setting but I can't get into settings
04-17-2019 10:10
04-17-2019 10:10
This is not a solution. It says to open the settings app and that is what I'm looking for. WHERE IS THE SETTINGS APP LOCATED???
04-20-2019 04:59 - edited 04-20-2019 05:03
@libragirl2 While on your Charge 3, swipe left three times. You should see "Settings" under the Weather app. Click on Settings. Brightness is the first option.
04-23-2019 14:21
04-23-2019 14:21
My Fitbit 3 doesn’t come brighter I have tried the settings and it doesn’t come brighter auto doesn’t work or brighteness. It used to be brighter. Need help please.......
05-02-2019 10:49
05-02-2019 10:49
There are only 2 settings Auto & Normal, both of which can not be seen in sunlight.
05-02-2019 10:52
05-02-2019 10:52
I do not see the screen time out under settings
05-02-2019 18:18
05-02-2019 18:18
05-02-2019 23:57
05-02-2019 23:57
There's not a time-out on the Charge 3. It's set to standard, which is about 4 seconds. Absolutely ridiculous setting!
