09-16-2018 02:47 - last edited on 11-17-2020 15:47 by MatthewFitbit
I am thinking of upgrading my charge 2 to a charge 3, can anyone let me know if it has an on/off button. I would like to turn off when I ride a motorbike as it always counts steps and it's a pain having to delete activites etc. It would be so much easier if o could simply turn off when I ride and then turn back on when I've finished. Thank you
11-01-2018 11:56 - edited 11-01-2018 11:59
I ended up exchanging my fitbit charge 3 for another because it would keep turning off then need a restart. It would function for maybe a day then turn off again. I received a new one a couple of days ago and I'm having the same problem. It randomly turns off (while on wrist), I restart it on the charger and it shows plenty of battery life. If this is user error I'm not sure what I could be doing differently. I have it paired to an iphone 6 if that matters.
11-01-2018 12:12
11-01-2018 12:12
@Freon-Leon Thanks for the update.
I'm sorry to hear that you are experiencing difficulties with your replacement Fitbit Charge 3. To provide assistance, I opened a case with Customer Support. I'm pretty sure they will be happy to evaluate your situation and find a resolution as soon as possible. Thanks for your patience in the meantime.
If you have any questions, please let me know.
11-06-2018 10:13
11-06-2018 10:13
I am having a Charge 3 at the moment, before a Charge 2. Only motorbike driving spoils everything. Is it possible to have a field driving under exercise button so the steps and hillclimbing are not counted.
11-06-2018 10:41
11-06-2018 10:41
There’s a feature request for a driving/pause function, but it’s been open for four years and has thousands of supporters and still hasn’t materialised so don’t hold your breath.
As a bodge you can log into your account, go to log and set that activity as Driving. Or you can use an app called Drive Bit which does this for you. Hit start and stop before/after you drive and it set so it as driving and discounts it.
11-06-2018 14:38
11-06-2018 14:38
@wietsma @LawrenceH Thanks for visiting the Fitbit Community.
At the moment, if your Fitbit Charge 3 registers steps or floors while driving, you can manually log an activity to negate the extra data. For more information please visit this article. Additionally, you can either wear your Tracker on the other wrist or if you haven't done it already, set the wrist setting as non dominant. You can find this option from the online Dashboard if you go to Devices > Wrist. Please make sure you sync after making any change to your account.
Like @LawrenceH mentioned, in the Feature Suggestions board there is a suggestion called Add "Driving Mode" Feature to avoid erroneous steps/floors. You can join the suggestion and if any update is available, it will be communicated as soon as possible. If you have questions about how Fitbit decide what Feature Suggestions are released please visit this site.
Keep on stepping.
01-11-2019 06:03
01-11-2019 06:03
How about just a pause step counting ffeature on the charge. I logged 6000 steps on Sunday in about 45 minutes while playing the piano at church. I don't have my phone available there.
01-13-2019 18:53
01-13-2019 18:53
@Bonded Welcome to the Fitbit Community.
It is not currently planned implementing a pause for the Fitbit Charge 3. For more information please visit this Feature Suggestion. If any update is available it will be communicated as soon as possible.
If you have any question, please let me know.
02-25-2019 22:26
02-25-2019 22:26
I am having the same problem with my Charge 3. It half-way worked for about a month, then it stopped syncing to my android and the time jumped 2 hours ahead. I have tried everything and nothing works with it. The Charge 2 was wonderful. Purchased Charge 3 at a department store and no longer have the receipt or I would return it.
02-26-2019 02:38 - last edited on 02-26-2019 13:58 by EdsonFitbit
there is a way to reset it. But you have to call them
02-26-2019 14:05
02-26-2019 14:05
@albeag Welcome to the Fitbit Community.
Thank you for trying to get the issue resolved before contacting us. Please make sure that your cellphone is part of the list of supported mobile devices. If so, perform a long restart which is different than the regular one, please follow these steps:
@KWJohn Thanks for your comments.
Please don't hesitate to contact us at any time if you need further assistance.
03-19-2019 08:13
03-19-2019 08:13
My fitbit is stop working what should i do
03-19-2019 19:31
03-19-2019 19:31
@jazzy45 Welcome to the Fitbit Community.
I'm sorry to hear that your Fitbit Charge 3 stopped working. Please be so kind to confirm that you have performed a restart and a long restart to your Tracker by following the troubleshooting steps provided above.
I'll be waiting for your response.
05-15-2019 07:05
05-15-2019 07:05
YES
Follow this link:
https://uk.ask.com/youtube?q=switch+off+charge+3&v=ijnofRhSzaI
Plug in charger and connect to Charge 3
Hold side touch button until bar fills across screen
Disconnect from charger
To switch back on simply connect to plugged in charger.
Moderator..... please remove the comment that it cannot be switched off as people are returning it if for example they ride a motorbike. The manual deleting of steps does not alter the status of exercise more than one hour if that was the duration of your erroneous step count.
Ta
12-25-2019 03:21
12-25-2019 03:21
Ridiculous that Fitbit can’t answer the question of how to shutdown Fitbit charger 3 but YouTube can...
04-20-2020 11:19
04-20-2020 11:19
I can’t
