11-29-2016
19:26
10:26
11-29-2016
19:26
10:26
11-30-2016 01:06
11-30-2016 01:06
Yes there should be no problem syncing to both
Wendy | CA | Moto G6 Android
11-30-2016 01:44
11-30-2016 01:44
11-30-2016 06:55
11-30-2016 06:55
@Mike2e Welcome to our Community! Another thing to add besides the bluetooth interference between devices that @Rich_Laue explain is that if you enabled notifications (for example on your iPhone) then you create a bond between the phone and the tracker and this will prevent it from syncing with other devices like your iPad. If you don't enable this feature then you shouldn't have any problem syncing with either of the devices you listed.
Let me know how it goes!
Best Answer02-03-2020 16:15
02-03-2020 16:15
I am having trouble syncing to both, seems like one or the other only!
02-03-2020 18:03 - edited 02-03-2020 18:05
While you can sync through both, your Fitbit, like most Bluetooth devices can only connect to one device at a time.
Therefore if both the iPad and phone are within say 100 feet, your Fitbit most likely is connected to the unit it last synced through. The other device, phone or tablet, won't be able to break into the connection.
Turning off the one Bluetooth will let the other device sync.
This is explained in the post above yours @Packergirl
09-06-2020 05:54
09-06-2020 05:54
There are problems! See the other replies
Best Answer09-06-2020 06:44
09-06-2020 06:44
Yes, I had problems doing it, told they had to be at least thirty feet apart! I just deleted off of iPhone.
Best Answer09-07-2020 10:49
09-07-2020 10:49
@AlvaroFitbit, @WendyB and I have explained the problem and the work around.
Simply rotten the bluetooth of on the device that you dont want to sync through.
This Issa needed because of the way bluetooth works ans is beyond the control of fitbit.
FYI: if the tracker recently synced through one device, the data Issa accessible to the other device without an additional sync. Both apps on both devices display the data from thre cloud services, not directly from the tracker.
01-21-2022 12:25
01-21-2022 12:25
I agree when I got the app downloaded on my iPad my tracker Fitbit stopped sycing
Best Answer01-21-2022 12:29
01-21-2022 12:29
It’s wasn’t my Fitbit tracker that stop it was the app on the iPhone that stopped. Oops typo
Best Answer01-21-2022 13:37
01-21-2022 13:37
If the app on the iPhone stopped syncing.
Make sure that the iPad is off or at least its BT. A BT device can only talk to BT host at a time.
Now we have a sync issue.
