11-22-2018
18:04
14:31
11-22-2018
18:04
14:31
Can you charge the Charge 3 with a cell phone charger that plugs in the wall? (As opposed to plugging the USB into a computer? Will it damage anything?
11-22-2018 19:04
11-22-2018 19:04
Yes, any standard 5 volt supply.
11-22-2018 19:04
11-22-2018 19:04
11-23-2018 07:56
11-23-2018 07:56
Hey @LHatch_29, it's great to see you around and @Den_in_USA thanks for the input.
I am glad to see here that our friend replied your inquiry about the charger. If there is anything else we can do for you, do not hesitate to post it.
Keep the stepping up!
11-23-2018 09:22
11-23-2018 09:22
@LHatch_29 Since we are on the charging topic, I want to emphasize that you should NEVER charge it from an external battery.
Laurie | Maryland
11-24-2018 10:50
11-24-2018 10:50
Can you charge off a Samsung fast charger without damaging the battery?
04-15-2019 23:19
04-15-2019 23:19
May i ask, how do you do this?
Thanks
04-16-2019 03:39
04-16-2019 03:39
01-12-2020 15:43
01-12-2020 15:43
why not? I've done this lots of times it charges just fine.
03-12-2020 16:39
03-12-2020 16:39
So here I am in 2020 with the question of will the adaptive fast charger hurt it? I can't find the input Volt number on any of the charge 3's packaging or pdf manual or safety booklet and whatnot. Even tho the charger says 9V-5V it fries some other small electronics i've used.
09-08-2020 08:40
09-08-2020 08:40
Hi, I know this is a few months late, but I wanted to give you my input on this. A device will only ever draw from a charger the max it can take. You won't "fry" your FitBit by using any sort of charger. Fast charging by default, however, does shorten any battery's lifespan. Usually, it's negligible "damage" and you'll most likely be upgrading your device before the battery's lifespan becomes an issue.
