12-02-2016
		09:49
		10:26
		12-02-2016
		09:49
		10:26
Every night when I go to sleep, my Fitbit Charge 2 lights up when I move my wrist in a position that it interprets as me lifting my wrist to check the time or my steps. This glowing light in turn wakes up my wife and makes sleep difficult for the both of us. Is it possible to turn off this feature at night so it won't light up during a predefined period each day? Otherwise, I might be forced to stop wearing it each night when I sleep which defeats the purpose of tracking my sleep patterns. Thak you in advance for your help.
12-02-2016 12:37 - edited 03-17-2017 19:29
Hello @DenverMike this feature is called quickview. if you go into you trackers settings you will be able to turn off quickview.
12-02-2016 16:01
12-02-2016 16:01
Excellent. Thanks again.
03-17-2017 19:27
03-17-2017 19:27
Thanks so much for finding this for me
Tess
 Best Answer03-22-2017 01:24
03-22-2017 01:24
Hi, so each time I go to bed I have to enable or desable this function?
Won´t it be easyer for users to set a "do not disturb" time zone?
Best regards.
03-30-2017 11:20
03-30-2017 11:20
I have Quickview turned off all of the time and that works fine during the day. However, the Blaze lights up every time I move at night, waking me and my husband.
04-18-2017 04:39
04-18-2017 04:39
My quickview is turned off and I leave it off. However, Fitbit randomly lights during the night, when I am not tochng the button..
04-18-2017 11:49
04-18-2017 11:49
It sounds like you are having the same problem that I am- with Quickview turned OFF, the Blaze lights up randomly at night when I am sleeping.  Right?  So, what can we do?  ![]()
04-18-2017 13:45
                              04-18-2017 13:45
If quickview is off, then a tap of the button or a double tab of the disply is needed.
Im not giving you an answer, just saying what is needed to turn the light on.
04-18-2017 15:11
04-18-2017 15:11
I don't really think I am double tapping or pushing buttons in my sleep. But interestingly, I find it hard or impossible to get it to do this during the day.
08-11-2017 12:02
08-11-2017 12:02
I think what most users are looking for is a feature update that allows us to control when the unit can light up. We don't want to manually turn it off/on each night/morning. We'd like to have a setting that we can configure to turn off the light-up feature automatically, for example off at 9pm and then automatically turn on the feature, for example at 7am. Can Fitbit include this feature soon?
08-13-2017 08:22
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              08-13-2017 08:22
@Ivanovich Thanks for joining us! You can vote for this idea in our Feature suggestions board. The more popular it becomes the more likely the developers will try to implement it.
Let me know how it goes!
08-13-2017 16:11
08-13-2017 16:11
I think it's a great idea. However, I have concluded that my Blaze is just defective. I have never turned on Quick View and yet all I have to do is tap my Blaze or shake my arm and it lights up. So now I just set the Brightness on Dim at bedtime and put a tennis wristband over it to block the light whenever it randomly lights up at night. Not a very satisfying solution to my problem, but easier to live with than before...
08-29-2017 13:53
08-29-2017 13:53
Since my Quickview is turned off already, I do not find that this is an actual solution. I bought my Fitbit partially to track sleep, but it keeps waking me up by lighting up randomly at night.
08-31-2017 08:46
08-31-2017 08:46
Did you, or anyone here, find a solution to this? I have this issue too and Fitbit Support has no answer (yet).
08-31-2017 12:16
08-31-2017 12:16
The only 'solution' suggested was to wear something over it when sleeping, but that's just like putting a band-aid over the problem, it does not fix it, just covers it up.
08-31-2017 12:22
08-31-2017 12:22
No, there doesn't seem to be a real solution. Just set the brightness to "dim", put a tennis wristband over it, and hope that when it lights up randomly, it won't be as bright. Pretty pathetic! It seems like turning the brightness off would be a good option, but dim is the best they offer.
08-31-2017 12:30
08-31-2017 12:30
Thanks. I don't see a 'dim' setting.
The tennis wristband is the current solution I'm working, but you're right, it's very pathetic!
08-31-2017 12:35
08-31-2017 12:35
On the Blaze, if you scroll over to Settings, it's right under Quickview (which says off!!!!) . It says Brightness, and you just touch it to switch between Dim, Normal, Auto and Max.
 Best Answer08-31-2017 12:39
08-31-2017 12:39
Got it. I'm on a Charge 2, which is why I can't find that setting. Thanks!
