03-04-2017
18:58
09:49
03-04-2017
18:58
09:49
Hi there! I've had the Charge 2 for a few months now (got it back in December) and I've been wondering how accurate the Cardio Fitness score is, and how exactly it is calculated. I currently have a 33 (which is poor for my age) but I don't think I have poor fitness. I'm 19 y/o female and I exercise regularly, as I'm a pretty avid runner. I'm also currently in college living on a big campus, so on a regular day I take at least 10K steps without exercise, and up to 30k with exercise. I run 4-5 times a week, running 3-10 miles per day depending on my training schedule, usually averaging out to 20-35 miles per week. I know the score is based on VO2 max, however, and I do have exercise-induced asthma. My HR to get pretty high during exercise, especially when running up hills (I take a couple of puffs of my inhaler before I go out for runs). Thanks for any insight! 🙂
09-18-2019 06:50
09-18-2019 06:50
Best Answer09-18-2019 11:12
09-18-2019 11:12
Best Answer09-18-2019 13:34
09-18-2019 13:34
14:18
12:45
EdsonFitbit
09-18-2019
14:18
12:45
EdsonFitbit
These parameters can be used to calculate heart condition. It would be of interest for Fitbit to see if they can calculate VO2max accurately based on HR data over the day. I did an attempt and with some more effort that should be possible. I will keep you posted if I manage.
Regards
Best Answer09-18-2019 20:33
09-18-2019 20:33
Best Answer09-21-2019 00:16 - edited 09-21-2019 00:17
I am still not 100% convinced that I am really as fit as the Charge 2 would have me believe, but I do think that an increasing cardio score must mean I am doing something positive. I am not young, so my scores are portrayed against my age and therefore won't look as high as some that are reported here, but I've been trying to run for about 6 weeks and my score has gone from 33.6-33.9-34 (Excellent - yay!) - 35 (last night's change). The interesting thing in the last change is that there has been no change in my rate or the exercise I have been doing night on night, but the score has increased. My resting heartbeat has consistently been on the lower side of normal in the last week, but there has been no huge change there. I use my phone GPS connected to the Charge 2 for the distance part of the run and sometimes the distance varies when it shouldn't, though not by much, but I did notice that last night it had reported a slightly higher distance than normal and I did wonder if the distance that you run has any bearing on the cardio score. According to Google maps the run should be 4.01Km, sometimes it logs as low as 3.97Km, and last night it logged as high as 4.58Km (which it can't have been!) I always set of end the run in the same place and turn on the top of the same man-hole cover! The fact that the increase in cardio figure occured on a night with a log that exceeded 4.5Km! I just wondered if the distance logged had anything to do with the suddenly increased figure?
Best Answer09-21-2019 04:22
09-21-2019 04:22
I thought I was doing everything right too, yet another week has gone by where I've recorded a weight loss as well as improved times and distances in my runs, my resting heart rate has lowered 1 point, and my HR is reaching my expected peak during training, yet my cardio fitness score has reduced again by 1 point.
I feel fitter and lighter, and that is reflected in my improvements when I run. Not sure where Fitbit is deciding my cardio fitness has reduced.
I should probably just ignore it. It seems nonsense to me.
06:41
05:15
JuanJoFitbit
09-21-2019
06:41
05:15
JuanJoFitbit
One thing that I know for sure about your variance in distance is due to the minor inaccuracy of GPS over small distances. + or – 50 to 100 feet over hundreds of mile is virtually zero, however, over the small distance you run and the small area covered the inaccuracy can adds up. Don’t be concerned with these minor variances. I tried using my Charge 2 for interval training (walk/run) based on maintaining an average pace. It was impossible because the varying distance in time significantly affected the pace. One interval would add distance to my course and another would take it away. Just when you think that you are ahead of pace and start to slow down, you then find yourself way behind pace while walking at the same pace!
Resting heart is a major factor, not the only one, in calculating your fitness score. The score is also a 4-point range, not a specific number, at least on my Charge 2. And, what do you expect for $100? It takes tens of thousands of dollars of equipment to actually measure your physical fitness and putting a number on it would be no better than pulling it out of a hat. There are a lot of shades of gray in deciding who is physically fit and who is not and to what degree.
As for fitness score, it’s just an approximation of relative “fitness” based on typical or average numbers for the general populous. Resting heart rate is a major factor. The other factors can only be derived from the data you entered about yourself; age, weight, etc. Try reentering your age to say, 20, and see how fit you are relative to a person your “age” (20). Again, take these data with a grain of salt and use the Fitbit as a motivator and progress indicator. After all, that’s all it was designed to do. For a real fitness measurement, see your doctor and ask for a total fitness stress test. I doubt your insurance will pay for it.
Sent from Mail for Windows 10
Moderator edit: merged replies
10-02-2019 01:30
10-02-2019 01:30
I think I have found out what is going on, as after more weight loss, improved running performance and lowered resting heart rate, I am now down to 41 for my cardio fitness, when I'd originally got it up to 48.
It seems there's an issue with my Fitbit connecting to GPS. It cuts out intermittently. When I check the run stats, my times are fine but the distances are off. The map shows gaps, and the total distance is much less than expected. I even did a walk this morning and it only recorded a distance of 1.5 miles over the course of 50 minutes, when it's just about a 3 mile route. I then did a run with Endomondo and there was no intermittent connection there and it tracked the full distanxe, so it's likely an issue with the device. My Fitbit is a few years old now...
Best Answer10-02-2019 06:47
10-02-2019 06:47
Best Answer10-30-2019 22:49
10-30-2019 22:49
It's almost always related to resting hr. When mine goes down, the score goes up.
Best Answer10-31-2019 11:37
10-31-2019 11:37
Best Answer10-31-2019 12:56
10-31-2019 12:56
10-31-2019 13:12
10-31-2019 13:12
Best Answer12-03-2019 15:03
12-03-2019 15:03
I have tried going on flat terrain tracked runs as recommended in the post and my cardio score is 22 (pretty much the worst score). I cant seem to get the score to change at all.
I am a 26 yr old with a resting heart rate of 62 which is excellent. I am a weight lifter so my BMI score is never accurate even though I am lean because I am fairly muscular. I do cardio training by trail running but it doesn't affect my score.
Any other recommendations that might help me out? I am disappointed that this is a function that just doesnt seem to work for me on my charge 3.
Best Answer12-03-2019 16:56
12-03-2019 16:56
Best Answer12-04-2019 07:47
12-04-2019 07:47
My average resting heart beat is 52 and my max is 190 which equates to a VO2 max 56 which would be good for a 28 year old However I’m age 68. Now I may be lucky genetically but I have been doing martial arts training for the last 27 years in a style that includes that equates to a lot of high intensity interval training ( lots of kicks, lots of Kata or poomse for Korean styles). Assuming you don’t end up at a McDojo, that might help.
Best Answer12-04-2019 08:00
12-04-2019 08:00
Best Answer12-04-2019 08:14
12-04-2019 08:14
Best Answer12-04-2019 15:07
12-04-2019 15:07
