07-30-2023 09:21
07-30-2023 09:21
Is there a way to change the brightness level from a cellphone or laptop? I started to change it on the Fitbit itself yesterday, after not using the Fitbit for months, and accidentally turned down instead of up, and now I have such a dark screen I can't even see to turn it on. It is fully charged.
07-30-2023 10:24
07-30-2023 10:24
Hi @JDDAsia these settings must be done on the app itself, there is no other way.
Best Answer07-30-2023 11:59 - edited 07-31-2023 06:34
Thank you for your response. I will try taking it in where I got it and see if they can see enough to fix it. Thanks.
07-30-2023 16:37
07-30-2023 16:37
I had the same problem. Apparently, there was a still a very feint image on my tracker but not enough to see what I was doing. Took it back to where I bought it from. They took it into a dark room and were able to change the brightness settings back to normal. Did not charge me at all for the service.
07-31-2023 03:36
07-31-2023 06:30
07-31-2023 06:30
Thank you for your reply. I will taking it in to the place I purchased it and see if they can fix it for me. Thanks.
Best Answer07-31-2023 06:32
07-31-2023 06:32
Yeah that is what I will do. Hopefully, they can get it figured out. Thank you for your reply.
Best Answer07-31-2023 06:35
07-31-2023 06:35
I tried that and couldn't get it. However, I plan to take it back to the place I purchased it and see if they can do the same to fix it. Thank you for your reply.
Best Answer08-01-2023 08:22
08-01-2023 08:22
I have the same issue, hadn't used it for about a year. Plugged it in to charge and i can't see the screen as it's so dark.. Tried in the dark but i still can't see enough to do anything
