01-15-2019
19:51
13:05
01-15-2019
19:51
13:05
When logging exercise, the default duration that appears is 30 mins. I would like to change this default to 45 mins. I this possible?
I do x6 classes per week that are all 45 mins long.
I searched in Help and the Community forums but couldn't seem to find anything. Possibly I'm using the wrong terms.
Thanks.
01-17-2019 10:16 - edited 01-17-2019 10:17
Hey there @Kylee7, it's nice to see you around here! Thanks for taking the time to search in the Community Forums before posting, nice way to go!
While reading your post I was wondering if you're talking about SmartTrack? If so, see: How do I automatically track activity with my Fitbit device? The minimum is 10 minutes and the maximum is 90 minutes.
On the other hand, you're manually logging the activity you can set the 45 minutes of the activity. But, I'm not sure where you're looking at. So I can better assist you, can you please send me a picture of what you're doing so I can go from there?
Looking forward to your reply!
Best Answer02-08-2020 20:30
02-08-2020 20:30
When you manually log an exercise the default duration time is 30min and the exercise start time is 30min before the time that the log is being entered.
how can I change the default to 0min-1hr?
this is not about autorecognizing exercise or mobiletrack
