07-06-2017
04:18
09:26
07-06-2017
04:18
09:26
My charge 2 battery life went from 4 days to 6 hours! I turned off notifications and the battery life still remains short and very inconvenient. Anybody experience this?
07-06-2017 04:50 - edited 02-08-2024 06:42
Hey there @DoeSister, welcome to the Fitbit forums!
The notifications are one of the things that may drain the battery on your tracker, nice way to go my friend!
However, I'd recommend taking a look at this post of mine to see what else may be draining the battery of your device.
Give this a try and let me know if you notice an improvement!
Best Answer07-06-2017 04:50 - edited 02-08-2024 06:42
Best Answer07-08-2017 04:17
07-08-2017 04:17
Hi, I followed your suggestions from Marrefitbit to no avail. My battery only holds a charge for 6 hours and it's disappointing. How do I return my charge 2?
Best Answer07-08-2017 06:21 - edited 02-08-2024 06:42
Thanks for stopping by @DoeSister!
Since you already tried what I've suggested without luck. I've shared your post with Customer Support, they will reply to you shortly.
Don't hesitate to let me know if you need further help!
Best Answer07-08-2017 07:25
07-08-2017 07:25
Thanks for your help.
Best Answer07-16-2018 12:22
07-16-2018 12:22
I started experiencing this on my wife's Charge 2, I have done the items in your original message and still have the same problem.
Best Answer01-21-2019 20:15
01-21-2019 20:15
My fitbit charge 2 is 18 months old and loses its charge within a morning. 18 months isn't a long time to own a watch which is not working properly.
What to do?
Best Answer01-22-2019 03:41
01-22-2019 03:41
Best Answer01-22-2019 16:28
01-22-2019 16:28
