02-09-2018
12:02
18:54
02-09-2018
12:02
18:54
Charge 2 screen went black. The green lights on still. I tried charging, restarting but no luck. It vibrates and shows working on app. Any ideas???
03-13-2019 06:25
03-13-2019 06:25
I just experienced the same problem though the heart rate charting is not always continuous. I sweat easily and because of climate usually wear long sleeves. I think water vapor from my sweat had built up inside the charge 2 display and shorted the display out but has not affected the other internal components. Look carefully at the display and you may be able to see a cloudy area on the screen. I think in my case it is moisture. I now have a newer water resistant version.
03-18-2019 13:50
03-18-2019 13:50
I charged my Fitbit last night and when I took it off the charger the display showed the full charge but now the screen is completely black/blank. I have no clue what happened. Can you assist please?
03-18-2019 14:48
03-18-2019 14:48
03-18-2019 15:02
03-18-2019 15:02
03-18-2019 17:14
03-18-2019 17:14
03-19-2019
14:46
05:53
AlvaroFitbit
03-19-2019
14:46
05:53
AlvaroFitbit
Thank you for the feedback on this. I think its shot. None of the
troubleshooting steps seem to have worked.
Moderator edit: removed personal information
03-19-2019 14:49
03-19-2019 14:49
03-19-2019
14:54
05:51
AlvaroFitbit
03-19-2019
14:54
05:51
AlvaroFitbit
For free?
03-19-2019 18:06
03-19-2019 18:06
03-20-2019 00:54
03-20-2019 00:54
I have work up to the same issue this morning. I had this before about a month ago and the reset worked but this time.no such luck. It doesn't restart when I plugged it in I saw it connect and say charge with the battery show on it. When i went to get it off charge it wouldn't light up. Any ideas would be great
03-20-2019 04:49
03-20-2019 04:49
03-20-2019 17:00
03-20-2019 17:00
03-20-2019 18:02
03-20-2019 18:02
03-20-2019
18:11
05:52
AlvaroFitbit
03-20-2019
18:11
05:52
AlvaroFitbit
Thanks! I did call support. They offered me a discount since I'm just
outside of my warranty. Although, I am not likely to spend more money on a
new device to potentially have the same thing happen in just over a yr. I'm
really disappointed about this process.
03-20-2019 18:17
03-20-2019 18:17
03-23-2019 03:46
03-23-2019 03:46
I have looked through all of this forum and tried all of the different ways of resting my Fitbit charge 2. It's started to lose parts of the screen then the information turned upside down and the screen went off everything else works fine apart from the screen. Has anyone managed to fix this problem or do you have to get it exchnage for a new one?
03-23-2019 17:16
03-23-2019 17:16
03-25-2019 22:31
03-25-2019 22:31
I have tried all the troubleshooting and nothing works I am having the same issue where the screen is blank it vibrates and the green lights are on
04-04-2019 06:35
04-04-2019 06:35
@JustTiff @jaumealaska @Jude0458 @bw2019 @AliceBeGood @ajhiggins @Coreena @FishnDan @Ododaks @Zanderbit @Mailiohana Welcome to any new members and thanks for your post here.
@JustTiff @jaumealaska @bw2019 @DanGoldstein @Ododaks @Zanderbit @Mailiohana I noticed that you already have tickets with support so please work with them and see what they can do for you. Many of you have mentioned you have been offered a discount.
@Jude0458 @FishnDan hope that your new device is working fine and is helping you keep up all those steps.
@AliceBeGood thank you for your feedback regarding the device.
@ajhiggins although it stopped working you mentioned that your Charge 3 is working fine now.
@Coreena happy to hear that Support was able to replace your device.
@ClareL87 I have created a ticket so Support can further assist you.
Keep me posted.
04-06-2019 15:26
04-06-2019 15:26
Same thing here. The screen for my Charge 2 has a blank screen while the green lights are on. I have tried the recommendations and posts from this thread but it did not help.
