02-09-2018
12:02
18:54
02-09-2018
12:02
18:54
Charge 2 screen went black. The green lights on still. I tried charging, restarting but no luck. It vibrates and shows working on app. Any ideas???
09-10-2021 07:35
09-10-2021 07:35
09-10-2021 17:00
09-10-2021 17:00
10-11-2021 15:07
10-11-2021 15:07
My fit bit is having the same issue as well.
10-13-2021 07:36
10-13-2021 07:36
10-13-2021 07:55
10-13-2021 07:55
10-13-2021 08:00
10-13-2021 08:00
10-15-2021
06:20
09:10
DavideFitbit
10-15-2021
06:20
09:10
DavideFitbit
that is shocking
Moderator edit: format
11-01-2021 16:39
11-01-2021 16:39
Lucky you! I am honestly just giving fitbit up and trying other fitness smart watches. Fitbit has been a great disappointment. After my charge 2 screen went blank last year, I upgraded to a charge 4. They offered me, like they usually do, a 30% off coupon and I bout a 4. It wasn’t cheap honestly. Wishing less than 6 months, that thing was dead. I was devastated and angry. I didn’t even call them but I should have, maybe I would have gotten a replacement since it was still working warranty. I don’t know if I am too late to contact them now but ai honestly believe they just sent me a piece of junk. It was a real ripoff. I am very very sad and depressed about the whole situation. These things are not cheap and the way the pandemic rages on, I would have loved to hang on to that thing for longer than the under 6 months I got. I don’t know what the recourse is but hopefully they can still replace it for me
11-02-2021 07:38
11-02-2021 07:38
Hi
My charge 3 has done the same thing this morning. The alarm went off but the screen is black. I have charged it fully and tried to restart it and clean it as you suggested but it’s still not working. It is syncing to my phone and my steps are being registered but there is nothing on the screen. Please can you advise further.
11-03-2021 02:34
11-03-2021 02:34
11-03-2021 05:05
11-03-2021 05:05
11-12-2021 15:22
11-12-2021 15:22
My fitbit charge 2 started with lines on the screen then went blank. The pro here is my fitbit charge now last 10 days, with no display. The con's pretty obvious, no display, can't tell one's progress, time, heartrate, steps, whether it's charging or not. Must do all through the fitbit app. Telling whether the charge 2 is charging or not is challenging. It's a Fitbit, I didn't expect the best when buying, it's lived up to it's lack of quality. Still work's with no display.
11-18-2021 22:37
11-18-2021 22:37
Hi Marre
Tried all the things you mentioned yet the screen is blank. The green lights at the underside keep flickering. The watch vibrates when put on charge.
Can you pls guide as to what could be wrong and how to fix the problem.
11-19-2021 00:01
11-19-2021 00:01
02-01-2022 11:57
02-01-2022 11:57
I’ve done all this and no luck 😩😩
02-20-2022 08:27
02-20-2022 08:27
My Fitbit charge 2 suddenly stopped working, won't turn on,won't charge when I try to, not even a vibration. I've tried troubleshooting but no sign of light but it's still connected to my app. Tried drying it out but won't still work. But once I disconnect it from power it blinks a green light twice and then goes off again but the screen remains black still
07-06-2022 21:49
07-06-2022 21:49
It has to be less than a year old. I’m so frustrated with Fitbit. Mines doing this as well. I’ve probably purchased 10 Fitbits total. They last a little over a year and something goes wrong and they’re past warranty.
07-07-2022
06:29
07:46
DavideFitbit
07-07-2022
06:29
07:46
DavideFitbit
Dear @AlvaroFitbit and team,
The screen for my Charge 2 has a blank screen while the green lights are on. I have tried the recommendations and posts from this thread but it did not help.
Your kind support would be highly appreciated.
Beside the black screen. The ‘track your exercise’, heart rate , steps, floors, exercise period, sleep and step/hour function are disappear.
Moderator edit: format.
07-07-2022 10:30
07-07-2022 10:30
07-07-2022 23:26
07-07-2022 23:26
Thank you FishnDan,
No sync problem, your answer it seems no solution to get the screen back to normal from black screen and no solution to recovery/set up exercise information that disappears.
Please let me know if I have miss understanding. Thank you.
