11-30-2016
00:34
10:26
11-30-2016
00:34
10:26
My Charge 2 display isn't bright enough..its almost unreadable...is there anyway to brighten the display ?
05-17-2018 12:02
05-17-2018 12:02
I'm having exactly the same problem, almost 2 years after the first post in this thread.
I contacted CS, hoping for a way to fix or repair the watch. Instead, I was told to search for the 'Suggest a feature' thread and put a request in 'To help future iterations of the Fitbit watches be even better'.
With all due respect to Fitbit, being told I should put in a feature request, when my watch is broken, is really, really bad service. This is a problem that a lot of people have. It's not simply a case of 'I wish my watch would do xxx'.
This isn't people losing their eyesight. This is the watch failing. If seeing the screen in daylight wasn't a problem when we bought the watches, but it is 12 months later, that's a defect. Plain and simple.
05-18-2018 14:45
05-18-2018 14:45
07-17-2018 05:55
07-17-2018 05:55
Correct. It is a defect/failure with the device. Mine failed during recharge this am. I was informed I was out of the 1 yr warrenty by 6 months (though total use time as shown by log was less that 6 month.) Best they could do was 25% off coupon. My online research reveals a lot of similar problems with fitbit priducts. While they do apparently honor the warrenty, they do not value their customers. Do not recommend fitbit products. There are plenty of alternatives out there.
05-15-2019
18:17
06:11
AlvaroFitbit
05-15-2019
18:17
06:11
AlvaroFitbit
I have the same issue. I bought a Fit 2 in June 2018 and it was completely unreadable = useless outdoors. I contacted customer service and they sent me a replacement which is identically unreadable = useless. They claim it is light adjustable which I assumed meant functional inside and outside but it is still unreadable = useless outdoors. How can a company sell a fitness device for outdoor use that is unreadable = useless?! This nuts. It never should have been released or sold to unknowing victims like me 😞 Many competitors products work fine outside. Maybe other Fitbit products work as well. But for me this was a waste on money and I won't buy another Fitbit Product unless they make me whole by replacing it with something that works. A discount couplon on a new product I have to buy is unacceptable.
Moderator edit: remove caps
05-16-2019 00:51
05-16-2019 00:51
Instead of trying to convince your fellow Fitbit users, I have searched the Feature Suggestion board, where users make their thoughts known to the developers and can not find a request for an increase in the Charge 2 brightness, but then again soon ot will be a year since the Charge 2 wa sold
05-24-2023 02:02
05-24-2023 02:02
No, the Fitbit charge 2 is not bright enough. When I'm outside you can't see the display. I have to find shade .
