08-20-2018
13:20
15:47
08-20-2018
13:20
15:47
Will the Charge 3 utilize the same charging cord/clip I use with my Charge 2? I gather straps are not the same, so will this be one more device where I'm forced to throw away accessories and buy them again? I guess that's what Fitbit wants.
08-27-2018 11:46 - edited 08-27-2018 11:47
@SunsetRunner has posted a CNET video in her post: https://community.fitbit.com/t5/Charge-3/Has-charge-3-wrist-band-attachment-been-improved/m-p/2920518/highlight/true#M304
Towards the end of the video, the charging cord was shown.
It is different charging cable than Charge 2, but definitely still the same clip type.
And from the back of the Charge 3, apparently we are still looking at the same "exposed" 3 metal contact plate for charging.
I have bad experience from these exposed plate, and had hope that Fitbit would upgrade the charging technology to magnetic. At the same time, the charging clip is simply too prone to break, when bringing out for a trip.
08-20-2018 13:25
08-20-2018 13:25
Fitbit lists the charging cable separately in their store, and the pictures look different, so I suspect that you won't be able to use the Charge 2 cables on the Charge 3.
08-20-2018 15:12
08-20-2018 15:12
It is a different charger to accommodate the updated heart rate sensors on the back of the Charge 3.
08-20-2018 17:19
08-20-2018 17:19
Hi @Heather-S. The charger for the Charge 3 is different than that of the Charge 2. Tap here to see it.
08-22-2018 23:22
08-22-2018 23:22
there is not much description on the charging cord.
from the pic, it seems like a magnetic charging pad?
08-23-2018 00:57
08-23-2018 00:57
Looking at the picture I thought it was more of a clip type - maybe similar to the Versa. But I cant see it well enough to be sure.
Helen | Western Australia
09-22-2018 09:29
09-22-2018 09:29
Will the fitbit 2 and the new fitbit 3 use the same chargers? I ask because I bought and aftermarket desktop charger for the fitbit 2 that I find very convenient to use.
09-23-2018 14:43
09-23-2018 14:43
@BobVA Welcome to the Fitbit family! Thanks for taking the time to post on this thread regarding the charging cable for Charge 3.
It is not the same charging cable as the Charge 2 one. They are the same clip type charging cable, but different. Every Fitbit accessory is unique for a specific tracker or watch type. You can use this charging cable for desktops as well by plugging it in to a USP port.
@NellyG @wind77 I appreciate you help on this thread a lot!
Keep me posted!
10-27-2018 18:18
10-27-2018 18:18
They are different but both TERRIBLE. Poorly designed and cheaply made
The 3 is worse than the 2 by the way, at least the 2 clicked into place
10-30-2018 12:37
10-30-2018 12:37
@Jbcmia Welcome to the Fitbit forums! Thanks for sharing your feedback regarding this matter.
What type of issue are you experiencing with your Charge 3 bands? Please let me know so I can assist you further.
Keep me posted!
11-23-2018 17:52
11-23-2018 17:52
Quick answer: NO.
This is the reply direct from Fitbit:
Me:I have 3 Charge 2 charging cables. Will they work on the Charge 3?
Reply: I would like to share with you that the charging cable for the Fitbit Charge 2 won't work with the Fitbit Charge 3 since they are different charging cables.
12-22-2018
11:56
04:16
AlvaroFitbit
12-22-2018
11:56
04:16
AlvaroFitbit
Completely ridiculous. Completely.
Moderator edit: format and remove all caps
02-11-2019 19:57
02-11-2019 19:57
I have just received a Charge 3 from Fitbit. I have had it charging 2 separate times for 1.5 hours each day. The charger only says 49% charged. What am I doing wrong?
02-11-2019 20:30
02-11-2019 20:30
02-11-2019 20:34
02-11-2019 20:34
02-12-2019 15:42
02-12-2019 15:42
Hello @GGlauser, it's good to see you participating in the forums for the first time. I'm sorry to see you've been having trouble with your Charge 3 battery not reaching 100%.
Before considering other options, please make sure you've exhausted all troubleshooting options in this article: Why isn't my battery charging?. If you continue to have the same inconvenience, please try to restart your device following these steps, and then try to charge it again to check if it's possible to reach 100% charge.
Thank you for your help with this too @btsuperman!
I hope this helps, please keep me posted.
02-12-2019 19:38
02-12-2019 19:38
02-13-2019 15:07
02-13-2019 15:07
That's good news @GGlauser, thank you for the update, it's good to know the device is charging again. Regarding the steps not being recorded correctly, could you please provide a few more details about what you've experienced? Or why you think the step count may not be so accurate?
Keep me posted.
01-03-2020 14:29
01-03-2020 14:29
And stores no longer carry the charge 2 chargers
