12-07-2021
02:08
16:36
JuanFitbit
12-07-2021
02:08
16:36
JuanFitbit
I have just bought a new Fitbit Charge 4. However the maps are STILL NOT SHOWING. I previously had a Fitbit Charge 3 and the maps also gave up showing over the past few months. I also don't see on the new Fitbit watch where I can change the activity to hike - it does NOT give me the option. And when I tried to find it on the app, it changed 10 minutes of the previous activity to hike???? Please help here - I am so done with this nonsense!?!?!?!?
12-08-2021 17:07
12-08-2021 17:07
Hi @melodieh . Thank you for your message and efforts.
Please keep in mind that the Charge 4 is a bit different as the Charge 3.
With the Charge 3, you'd to use Connected GPS (GPS from your phone connected to your Charge 3) to record a map.
The Charge 4 has different settings depending if you want to use Connected GPS, the integrated GPS or a dynamic between both of them.
I'll suggest you to have a look at this: How do I manage the GPS settings on my Fitbit device?
How do I get my Fitbit device to connect to GPS?
See you around.
Best Answer12-09-2021 03:29
12-09-2021 03:29
Best Answer12-09-2021 16:38
12-09-2021 16:38
@melodieh , Thank you for your message and efforts.
Could you verify if the map is shown on your online Dashboard? (fitbit.com)
How do you start your record? On the Fitbit app on the phone or on the tracker?
See you around.
Best Answer12-09-2021 22:11
12-09-2021 22:11
Best Answer12-12-2021 16:40
12-12-2021 16:40
@melodieh , Nice to see you back. Thank you for your reply and further information.
To add hie again to your Charge 2, please have a look at this: Can I change or reorder the exercises on my Fitbit device?
I also recommend you to read this : How do I use GPS on my Fitbit device?
See you around.
