07-14-2020
21:12
09:14
07-14-2020
21:12
09:14
My charge 2 is going though the menus without me actually going though them using my finger and it drains my battery over night. It charges but does not hold a charge. Is there a way to fix this or should I just get a new fit bit?
07-14-2020 22:25
07-14-2020 22:25
@VibrantAutumn have you checked that the button is all clean and not being held down constantly?
07-27-2020
12:41
09:28
07-27-2020
12:41
09:28
@VibrantAutumn Thanks for stopping by!
Let me help you with your Charge 2 screen issue and the battery draining quickly. Beside checking the button like @Joyouscrayon565 mentioned you can try cleaning the contacts using cotton swab with rubbing alcohol, then charge it by plugging it for a couple of hours directly to your computer's USB port (try different ports) or use an UL-certified USB adapter. After this, restart your device to troubleshoot the screen and see how it behaves. You can follow these instructions to help improve the battery life.
Let me know how it goes.
07-27-2020 16:09
07-27-2020 16:09
Thank you for the reply’s. I have done all those suggestions. I have bought a new Fitbit since those options didn’t work. I will be retiring this Fitbit.
08-04-2020
10:49
09:28
08-04-2020
10:49
09:28
@VibrantAutumn thank you for your reply.
Since the issue persists I have created a ticket so our Support team can further assist you via email.
