04-02-2019
18:28
16:45
04-02-2019
18:28
16:45
My Charge 2 wristband broke. Will the Charge 3 wrist band replace it.
04-02-2019 18:34
04-02-2019 18:34
I don't think so because the designs are different. However, I was just on Amazon.com. They sell lots of Charge 2 wristbands.
Best Answer04-02-2019 23:53
04-02-2019 23:53
Hi @RogerNelson Welcome to the Community. @AnnJTexas is correct they are not interchangeable. Do have a check though to see if you are still under Warranty If you are you will be able to log a case with Customer Support to get it replaced.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
Best Answer04-03-2019 05:32
04-03-2019 05:32
