04-21-2019
03:53
16:26
04-21-2019
03:53
16:26
Any idea when the Charge 2 will be compatible with the Galaxy S10. I was disappointed when I got my new phone and found it wouldn’t sync.
04-22-2019 07:40
04-22-2019 07:40
@robink902 Welcome to the Fitbit Community! I hope you're doing well!
I will gladly assist you with your syncing issues. As you mentioned your phone doesn't show as compatible but that doesn’t mean it won’t work it just means that it hasn’t been tested by our team. You can try going to your phone's bluetooth settings and remove all devices listed there. Restart your phone and restart your device. After this try syncing them. Also, if you are using an Android device, check that your app has the necessary permissions (settings > apps > Fitbit > permissions) and make sure bluetooth and location services (GPS) are on. You can find additional suggestions here.
Please be aware that Android users are having issues syncing with Android 9 (Pie), you can check this thread to keep up to date with this.
Let me know how it goes.
04-23-2019 07:38
04-23-2019 07:38
It is working now. Thank you so much!!!
