02-13-2017
08:55
10:13
02-13-2017
08:55
10:13
I'm beginning training to play roller derby, and was wondering if the Charge 2 would be okay under my wrist guards. Anyone have any experience?
02-13-2017 09:33 - edited 02-13-2017 09:35
I don't see why it wouldn't work. I wear a wrist support over the tracker while lifting weights with no problems. I like to think it even helps protect the screen. Only downside is a couple of times the heart monitor stopped getting signal, and I had to remove the wrist support in order to adjust the band.
Roller derby looks pretty intense in terms of physical contact. Do you think the wrist support will protect the tracker enough?
Roller derby is pretty cool!
02-13-2017 09:34
02-13-2017 09:34
Thanks friend! Now I can't wait to get mine for my birthday!
08-29-2018 13:24
08-29-2018 13:24
How did it go I got the versa and was contemplating duct taping to my body lol
08-29-2018 17:37
08-29-2018 17:37
Might want to rotate it so screen not as exposed to contact, though might not detect heart rate as well.
08-30-2018 06:56
08-30-2018 06:56
It went really well. I just made the strap loose and had it above my wrist guard. I think it kept up the stats really well (HR, calories, etc), everything except steps which is understandable since I skate.
08-30-2018 06:57
08-30-2018 06:57
I only wear it during training. Not game play.
02-04-2020 20:12
02-04-2020 20:12
Came here for the same reason! I hate not being able to wear it during practices!
