06-23-2019
11:11
15:06
06-23-2019
11:11
15:06
Hi, I take part in spin classes, and after the class when I sync my fit bit, and add the exercise under spinning with time length. I keep getting standard calories 259 each time. Does anyone know why? As my hr is different in each session. Thanks
Moderator edit: title format
06-24-2019 08:36
06-24-2019 08:36
@Flooder13 Welcome to the Fitbit Community! It's great to have you here!
Let me help you with your Spinning class data. How do you log this activity (via the Fitbit app or through the activity modes on your Charge 2)? If you are manually logging the activity I suggest you allow your tracker to record it instead so the heart rate data is taken into consideration. You can read more about using the activity mode here.
Let me know how it goes.
Best Answer06-25-2019 09:14
06-25-2019 09:14
