01-26-2019
13:18
17:54
01-26-2019
13:18
17:54
My charge 2 band erroneously "unhooks". I lost my last one 9 months ago due to this problem. I am now ducttaped. Is this a common problem? Will buying a new band correct this or is the problem with the fitbit devise itself and finally, is it under warrentee?
01-26-2019 13:53 - edited 01-26-2019 13:55
@EvichProp Its worth checking with Customer Support to see if it can be covered. Your Charge 2 would need to have been bought brand new from Fitbit or one of their approved suppliers. The warranty would be 1 year from the date of purchase, however if you reside in the EU and also purchased it within the EU you would get 2 years warranty.
Tony | UK
Ionic, Versa 2, Charge 3 SE, Aria 2, Flyer, Note 9, Android 8.1, Windows 10
01-26-2019
22:00
10:34
AlvaroFitbit
01-26-2019
22:00
10:34
AlvaroFitbit
When you say unhook, do you mean unhooking from the Fitbit peeble?
If so then the metal plate may be bent or the connecting point on the tracker damaged .
01-27-2019 10:46
01-27-2019 10:46
I have had my charge 2 for just over 1 year and I am just about to buy my 3rd strap. They seem to break easily if caught on anything. I have had to stop wearing mine at work because of this so now I don't get accurate daily step readings which is really annoying. Good job the straps are not overly expensive.
